Init.d For Ics
Posted 22 June 2012 - 05:01 AM
Posted 22 June 2012 - 05:06 AM
You would need an init.d mod for Bootstrap. Safestrap has issues with them.Does anyone have a working init.d implementation that only installs the hack and doesn't de-bloat?
Posted 22 June 2012 - 05:27 AM
Posted 22 June 2012 - 05:43 AM
I would talk to EmericanX about that, not my area sorry.Ah, ok. EmericanX said he had one & I just assumed it'd work on SS because that's what the roms use. Any way to just push/edit the files necessary to implement it? Sent from my DROID RAZR using Tapatalk 2
Posted 22 June 2012 - 06:15 AM
Posted 22 June 2012 - 06:23 AM
The method I have as of right now isnt working on the latest leaks. IE:211 safestrap... as soon as I make progress you'll will know.
Thanks man.
Posted 24 June 2012 - 08:05 AM
Maybe you could try that one
Sent from my XT910 using Tapatalk 2
Soundcloud <> Bassgrow
Posted 24 June 2012 - 08:23 AM
I modified DT's complex_modifier to remove the debloat scripts. I'll test it and post my results.
Posted 24 June 2012 - 04:22 PM
http://forum.xda-developers.com/showthread.php?t=1710980
Thanks, been playing around with this since yesterday, trying to get it to work. It looks like the key is to create an install-recovery.sh to direct the os to the init.d scripts. Only problem is I already have an install-recovery.sh & don't want to mess with it.
Posted 24 June 2012 - 04:28 PM
Thanks man, hope it works. My only concern with axiom is that it doesn't seem to play nice with safe-strap. I had used his full mod on the .75 leak at first & I couldn't get SS to work with it even after going through DT's removal process. I had to fastboot back to remove it so I could move up. I really hope it works & thanks for taking a crack at it.
Posted 24 June 2012 - 05:23 PM
I've used the DT's AXI0M_CMPLX_MODIFIER.zip on a few roms and I'm running RAZRSafestrap-ICS-2.00. I haven't had any issues to date.
I ran my modified version on a fresh install on Eclipse and so far, no issues. Here's the script but I'd recommend making a nandroid just in case. The modifier still loads DT's tweaks.
Note that the install still says DEBLOATING but it's not. I didn't remove that line of text.
If you hang on either the Moto logo or "Android is updating", force a reboot. This happens on occasion.
Posted 24 June 2012 - 06:30 PM
Posted 24 June 2012 - 06:51 PM
- Jarras likes this
Posted 25 June 2012 - 02:18 AM
Ive got it built into SimplexROM... but if theres interest i can put together a flash zip that will enable it for stock rooted.
Always interested in flashable zips
- Jarras likes this
Posted 06 July 2012 - 04:00 PM
Yes please!
Posted 06 July 2012 - 06:47 PM
Posted 06 July 2012 - 07:55 PM
I plan on playing with it and the govenors tomorrow.
Posted 06 July 2012 - 07:57 PM
Doing that right now.init.d installer over here.
Posted 07 August 2012 - 07:02 AM
any help will be greatly appreciated!
Thanks!
Posted 07 August 2012 - 08:17 AM
Yep, the EZInit.d installer referenced above will work on stock, rooted ICS.is there anyone can run init.d scripts with stock rom? (because i dont want to reflash my stock rom)
Thanks!
