Call Recorder
Posted 22 June 2012 - 10:52 AM
Posted 22 June 2012 - 11:00 AM
Posted 22 June 2012 - 11:33 AM
I am fear my blade!
Posted 30 June 2012 - 07:42 PM
Posted 09 July 2012 - 10:22 PM
It's called "Call Recorder."
You need to also install the ALSA Mixer for this to work. It uses software to record both incoming and outgoing. It is impossible to record using the hardware (for a perfect copy) without a custom made driver specifically for the chipset this phone uses, which hasn't been done and probably never will. But this does work, despite sometimes being a little quiet, it works fine.
Posted 10 July 2012 - 12:57 AM
Incorrect: THERE IS A CALL RECORDER THAT WORKS ON RAZR. I've been using it for quite a while. You have to be rooted.
Thanks Neo, I will check it out...
Posted 10 July 2012 - 04:00 AM
All in all it does work. No where near as good as my current app. But we will see. For 10$ I expected a lot more.
I am fear my blade!
Posted 10 July 2012 - 06:02 PM
Which has much much better quality and is more reliable.
All in all a good app, as I used it on my thunderbolt, but a fail on the razr. 10$ waisted. O well
I am fear my blade!
