Posted 22 June 2012 - 11:08 AM
Posted 22 June 2012 - 11:15 AM
Posted 22 June 2012 - 11:20 AM
Check background data in data manager. When background data is disabled, google will not sync
Posted 22 June 2012 - 12:06 PM
When it is blue, means your google account is synching.
That's all on. 4g turns blue almost instantly. It's only when it's on 3g only that this issue occurs.
#5 Guest_BDH_*
Posted 22 June 2012 - 12:32 PM
Bad 3G radio? Have you tried reflashing the leak?
Posted 22 June 2012 - 12:37 PM
Posted 22 June 2012 - 12:44 PM
Yes, did it twice. Actually re downloaded it then reflashed it just in case the first one was somehow corrupted.
#8 Guest_BDH_*
Posted 22 June 2012 - 12:51 PM
Might be a hardware issue.
Posted 22 June 2012 - 12:52 PM
I've been on .211 for a while. Switching back and forth from 4G to 3G only with no issues. 3G stays gray for a while after the switch, but blue does show up. And everything works. Are you switching to CDMA only or CDMA auto (PRL)? I used the "auto" one.
cdma auto (prl)
Posted 22 June 2012 - 12:57 PM
So I decided to just leave the 3g on to see if it eventually turned blue and it does. Averages 3:26 minutes to turn blue (timed it 3 times). 4g turns blue in under 10 seconds....Weird huh?
#11 Guest_BDH_*
Posted 22 June 2012 - 12:58 PM
UPDATE:
Wow that's crazy
Posted 22 June 2012 - 01:00 PM
cdma auto (prl)
Hmmm, I have not had any issues, but I nuked all my data (multiple times) going through .181 to .211, so I was starting completely fresh. And I was very selective in data restore for user apps with none of system app restores. I can only tell you that on clean slate I have no data issues with 4G/3G switch, but I know that's not helping you much. Did you try a factory reset with absolutely no data restore and see if the switch works for you then?
Posted 22 June 2012 - 01:21 PM
I've wiped my cache, dalvick, factory reset, nose, and butt in an attempt to get this working right with no luck.
Posted 28 June 2012 - 04:38 AM
Posted 28 June 2012 - 04:58 AM
I have the OTA .211 since Friday evening (soak test) and I have noticed the same thing. Unfortunately they have taken the CDMA only option away so now it is GSM, LTE or Global settings. But to the point...I live in a marginal 4g areas so the phone is constantly switching back to 3g and it does take a long time for the 3g to reestablish a data connection.Ok, so I have been going nuts trying to figure this out. I was on .209 with no data issues at all. I jumped up to .211 (twice) and I have this problem: I like staying on 3g only to conserve battery. On this .211 leak, the 3g does not turn blue. I get internet, but google play is AFU while on 3g only. 4g works perfectly. Anyone else have this problem? is there a fix?
Posted 28 June 2012 - 06:29 AM
Also tagged with one or more of these keywords: .211, 3g
