{ROM} GZR Presents Validus13
144 replies to this topic
#1 somber73
somber73
    Ringmaster
  • 466 posts
  • Twitter:@xSomber73
  • LocationNY
  • Current Device(s):Razr M
Posted 19 September 2013 - 12:41 PM
    Latest CM Bells & Whistles
    Battery Bar. You can choose to be shown in Status Bar or under Navigation Bar and plus choose thickness, different colors and charging animation;
    Circle Battery with 4 different types of charging speeds and possibility of color customization (battery icon and percentage text);
    Turn screen on when plug/unplug the USB cable as an option in settings;
    Reboot Menu Enable by default;
    Brightness control sliding through status bar;
    Custom Carrier Label;
    Status Bar Transparency and Custom Colors;
    Status bar network speed indicator with option to custom colors;
    Option to auto hide network speed indicator when there is no traffic;
    Status bar quick peek;
    Notification drawer + Notification row Transparency, custom Colors and custom image;
    Navigation Bar Height, Width and Width in Landscape. Also Transparency and Custom Colors;
    Notification Behavior (Normal, Always Expanded, Never Expanded and Old Style);
    Low Battery Warning (Pop-up and sound, Notification and sound, Pop-up dialog only, Notification only, Sound only, Disable);
    Appbar from ChameleonOS;
    Lockscreen based on gestures from ChameleonOS;
    HALO 2.0 by ParanoidAndroid;
    BlackUI (Darkness), TRDS from Slim Roms;
    LCD density changer
    Option to enable notifications light even with screen on;
    Option to enable lock screen rotation;
    Open tiles in floating window;
    QS tile fast charge;
    Powerwidget toggle fast charge;
    Speed up statusbar / notification drawer;
    Alternate default app picker;
    Customizable lockscreen (color fill with transparency slide, custom image with transparency slide, full transparent, default wallpaper);
    Floating window from notification drawer (Long press);
    Option to show Wifi name in notification drawer;
    Option to flip tiles in simple press;
    Listview Animation;
    Listview Interpolator;
    SlimRoms Nav bar
    SlimRoms PIE
    Expanded desktop mode with 4 options (off, hide status bar, hide nav bar, hide status and nav bar)
    More to come........
      1. Follow normal flashing rules
      2. Use only 4.3 Gapps
      3. Enjoy
Big Thanks:
Cristiano Matos(for his wonderful concept)
dustinb(beautiful themes)
DrDevs
CM Moto team
SlimRoms
And many more :)
Download
Custom Wallpapers:
  • neckchop, timpohladthomas, shane1 and 4 others like this
#2 dragon
dragon
    Puff the Magic Dragon
  • 166 posts
  • Twitter:foamerman
  • LocationLand of Honalee
  • Current Device(s):Unlocked RAZR MAXX HD retired Bionic, Thunderbolt and OG Droid
Posted 19 September 2013 - 12:53 PM
First.... download broke sorry 404
#3 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 19 September 2013 - 01:00 PM
How is 3G 4G data on this?
#4 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 19 September 2013 - 01:04 PM
Link Fixed  ran fine for me all day
#5 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 19 September 2013 - 01:05 PM
Taken care of thank
#6 DroidAddict101
DroidAddict101
  • 259 posts
  • LocationBinghamton
Posted 19 September 2013 - 01:49 PM
Yeah. I'm gonna have to try this. Been hearing good things
#7 dragon
dragon
  • 166 posts
  • Twitter:foamerman
Posted 19 September 2013 - 02:57 PM
Taken care of thank
Thank you Sir  :)
EDIT: got a question I have read around that TWRP 2.5 does not play nice with some 4.3 roms that are out now will this one play nice with 2.5 or do we need to be on 2.6.1?? thank you again
#8 cj360
cj360
  • 85 posts
  • Current Device(s):Razr HD
Posted 19 September 2013 - 03:35 PM
I've been on 2.5 twrp since it was posted, no issues when I tried 4.3 roms such as carbon, slim, pa.
#9 llawen
llawen
    android tweaker
  • 551 posts
  • Twitter:@llawen
  • LocationGlenn hieghts, Texas
  • Current Device(s):razr maxx hd
Posted 19 September 2013 - 03:54 PM
Hi I'm Llawen, and I'm a crack flasher. Going to flash this bioutch.
Sent from my Razr HD using Tapatalk 2
  • neckchop and somber73 like this
#10 bjoostema1933
bjoostema1933
  • 122 posts
  • LocationNorth Carolina
  • Current Device(s):Razr HD Maxx /Nexus 7
Posted 19 September 2013 - 06:38 PM
Runs awesome so far man! Will test out the battery life after fully charging tonight.  Not a single reboot while setting everything up, which is a first for me on 4.3.  Thanks for this!
#11 bjoostema1933
bjoostema1933
  • 122 posts
Posted 19 September 2013 - 06:59 PM
It's been the same for me as all other aosp 4.2+. It connects at 1 min and 6 secs after rebooting, no data drops as of yet and the same signal strength. ymmv but it's solid on my end buddy, and I live in a less than desirable service area.
#12 wooddale
wooddale
  • 936 posts
  • Twitter:benuti1
  • LocationIl & WI
Posted 19 September 2013 - 07:38 PM
I'm in a real crap area
I'm in a real crap area I have tried 4.2 and not so good 4.1.2 works as good as it could. Should I give it a shot?
#13 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 20 September 2013 - 01:59 AM
Wouldn't hurt to try :)
#14 bjoostema1933
bjoostema1933
  • 122 posts
Posted 20 September 2013 - 03:49 AM
Like Somber17 said, it definitely won't hurt to try.  Usually, just going from the front of my house to the back will cause a bar or two on my signal icon to drop.  On this ROM, it stays consistent.  I don't know how great of an indication that is, as I probably need to check the numbers under signal strength to verify.  As far as the rest of the ROM, it runs ridiculously smooth and (knock on wood) I haven't had any hiccups yet!  I'd give it a try buddy, but that's just my opinion.  Signal is fine on my end and that's usally something that gives me a little grief considering my service area.
#15 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 20 September 2013 - 04:09 AM
Somber17? Lol. Just Messing thanks for your input
  • bjoostema1933 likes this
#16 bjoostema1933
bjoostema1933
  • 122 posts
Posted 21 September 2013 - 03:38 PM
Still running awesome after a couple of days with heavy use. I've had only one reboot, but that may have been app related as I tend to tinker constantly with root apps.  Great job somber73!  I'm truly grateful for the devs keeping this phone alive!
  • somber73 likes this
#17 Mad Cutter
Mad Cutter
  • 30 posts
Posted 23 September 2013 - 05:59 PM
Just don't let your battery die on this ROM. Mine died in the middle of typing a text and acted kind of crazy when it was shutting down. After charging back up I couldn't boot past boot logo. It wouldn't even let me boot to recovery if my charger was plugged in. I tried restoring several different backups, wiping everything and flashing different roms, flashing boot img, nothing would work. I had to fastboot back and start over (with rootbox of course). This sucks because the ROM ran perfect up until this point. I really liked it.
#18 somber73
somber73
    Ringmaster
  • 466 posts
  • LocationNY
Posted 24 September 2013 - 04:28 AM
:blink:
#19 asilentcivilian
asilentcivilian
  • 28 posts
Posted 25 September 2013 - 02:19 PM
Lol. Wtf?
Sent from my XT926 using Tapatalk 4
#20 jeff0r3
jeff0r3
  • 55 posts
  • Current Device(s):xt926
Posted 25 September 2013 - 04:01 PM
WELL...  I've been a big fan of Somber73's releases.  So because of all the funk and crap going on with the "Unofficial" blahblah, I'm moving on to this rom..  Sad, but Oh well!
  • shane1 and somber73 like this
