help me please...error- E:failed to mount \data (invalid argument)
what to do?recovery TWRP 2.2.2.1 not works(((
Posted 19 September 2013 - 12:42 PM
Posted 19 September 2013 - 04:48 PM
Where can you get to on your phone? Are you rooted? Do you have safestrap?
___ ___ ___ ___ /\ \ |\__\ /\ \ /\ \ /::\ \ |:| | /::\ \ /::\ \ /:/\ \ \ |:| | /:/\ \ \ /:/\:\ \ _\:\~\ \ \ |:|__|__ _\:\~\ \ \ /:/ \:\ \ /\ \:\ \ \__\ /::::\__\ /\ \:\ \ \__\ /:/__/ \:\__\ \:\ \:\ \/__/ /:/~~/~ \:\ \:\ \/__/ \:\ \ /:/ / \:\ \:\__\ /:/ / \:\ \:\__\ \:\ /:/ / \:\/:/ / \/__/ \:\/:/ / \:\/:/ / \::/ / \::/ / \::/ / \/__/ \/__/ \/__/
Posted 19 September 2013 - 04:52 PM
First off, if you can get into fastboot, I would flash a newer version of TWRP. Then, try it again.
Posted 19 September 2013 - 11:51 PM
fastboot work..flash recovery not work..error E:failed to mount \data (invalid argument).RSD no flash xml ERROR- FAIL. device razr hd xt926.root yes.loader unlock.recovery-TWRP 2.2.2.1
Posted 20 September 2013 - 03:33 AM
Sig by
Posted 20 September 2013 - 06:25 AM
That makes no sense. Flashing recovery doesn't touch the data partition. How did you try to flash it?
Fastboot flash recovery nameofopenrecoveryhere.img
From My S4 Dev Edition
It looks like he might have flashed in RSD. I'm not sure though.
Posted 20 September 2013 - 07:15 AM
What the heck version number is that for TWRP.......since the latest is 2.6
Posted 20 September 2013 - 11:59 AM
I'm part of the way through conversion to bash script..... Stay tuned.
Posted 20 September 2013 - 12:04 PM
I told you I was going to work on it. I had to finish my ODIN script for the S4 first. But I'm on the bash stuff for the HoM.
Posted 20 September 2013 - 12:21 PM
I do that?format the entire memory in Linux?
Posted 20 September 2013 - 12:24 PM
No, no, sorry, our conversation had nothing to do with your situation. Other than I wrote a tool called the House of Moto that's designed to help people flash their FXZ's a little easier. I would try to return everything to stock and start over.
Posted 20 September 2013 - 01:00 PM
HouseOfMoto not work(((
Posted 20 September 2013 - 01:28 PM
Yea, that's one broken phone then, sad to say.
Posted 20 September 2013 - 02:23 PM
how to do the Low-level formatting in Linux?they say will help...
Posted 20 September 2013 - 02:45 PM
I'm not sure I understand. Certainly don't know how to do what you're asking.
Posted 20 September 2013 - 03:05 PM
guys who are strong in Linux?help to make the formatting in Linux
Posted 20 September 2013 - 05:14 PM
Posted 20 September 2013 - 05:29 PM
did not help all of the above..house of moto -failed..Rsd-FAIL.Matt's utility-not help.
it is necessary to reset the flash memory in linux .. put zeros ... I do not know how
I threw in a music phone .. it freezes .. had to do a reboot and went errors
was officially firmware 4.1.2
Posted 20 September 2013 - 05:33 PM
Uh, yea, good luck with that. Your phone is unfortunately screwed up. If the RSD fails, well, yea.
