I have Titanium Backup and the pro key. I have Dropbox on my phone and is setup.
When I run Ti Bu, it says that dropbox, box and google drive are INACTIVE. How do I tell Ti Bu to activeate them?
2 replies to this topic
Posted 23 June 2012 - 05:34 AM
Posted 23 June 2012 - 05:40 AM
Make sure Google drive and drop box are activated and your signed in. Or re-install tbp
a what? an android? whats that?
Posted 23 June 2012 - 06:59 AM
Setting up dropbox for TiBu is a pretty counterintuitive process. I too had to search around to figure out how to set it up. Go into the preferences menu in TiBu, one of the first options in the list is Coud Sync Settings. Pick which ever cloud service your're gonna use and check it. There are settings for the cloud service, but I left them as default. But you're not done! Go back to the main TiBu screen and on the top select Schedules. In this menu you should now see a Sync to Dropbox addition. Click Run, it will then as you to put in your password. You then sync up your dropbox Account with TiBu. A suggestion: Make a label called "User Apps" or something like that and select just your user installed apps, otherwise TiBu will try to sync EVERYTHING with your dropbox and for me it was almost 1 gig with of stuff. You create labels by going to "Backup/Restore" and then "Click to edit filters". On the bottom you make labels. I dont know about you, but if for some reason, I forget to turn Wifi on and my TiBu sync's with dropbox at 3am on Sunday morning well there goes 1/4 of my monthly data allowance. So yea, make a label of just your user apps this way it only syncs what's needed. That's about it. Took me a little bit of time to figure out how to set this up. When you click the Dropbox schedule, there's an "Edit" option. In that menu is "Elements to Synchronize" Then you can select the label that you've created with just your important apps.
