Wifi Tether No Longer Works Has Ad Hock Error?
Posted 23 June 2012 - 08:36 AM
Posted 23 June 2012 - 09:29 AM
#3 Guest_BDH_*
Posted 23 June 2012 - 09:42 AM
I was going to use 1.7 but instead I updated with the verizon download. I unroofed with voodoo and then rerooted. Wifi tether is 3.1 beta 14 and when I start it up I get a ad hock error. Anyone know how to fix this please.
Look for KOA ROM in the development section. In Post 3 I have instructions for getting it to work.
Posted 23 June 2012 - 10:00 AM
I have a similar issue, wifi tether turns on but computer connects with limited access with no internet. Tried those settings and still nothing. And i used 1.7 to update.Look for KOA ROM in the development section. In Post 3 I have instructions for getting it to work.
#5 Guest_BDH_*
Posted 23 June 2012 - 10:06 AM
Tried FoxFi?
Posted 23 June 2012 - 10:24 AM
I could not find the KOA thread but thanks anyway.
Posted 23 June 2012 - 10:55 AM
thanks, that worked, took a while to connect, had the limited access again at first, but eventually worked unlike wifi tether.Tried FoxFi?
Posted 23 June 2012 - 11:35 AM
Posted 23 June 2012 - 02:27 PM
so far the sqlite hack not working.....
When I use the sqlite hack I can't see the network on my touchpad for some reason. I can see it fine with foxfi tho
HP Touchpad CM9
Posted 23 June 2012 - 06:46 PM
Posted 23 June 2012 - 07:35 PM
Does anyone know if the Verizon paid hotspot feature works?
Paid tether works fine, works great with the notification toggle app too.
Posted 24 June 2012 - 04:06 AM
Posted 25 June 2012 - 10:35 AM
Posted 25 June 2012 - 10:46 AM
Posted 25 June 2012 - 11:20 AM
Sent from my .211 leak razr do you wanna get cut?
Posted 25 June 2012 - 11:25 AM
Posted 25 June 2012 - 12:20 PM
Posted 25 June 2012 - 12:38 PM
