Help! My radio has fallen, and it can't get up.
4 replies to this topic
#1 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
  • Current Device(s):DROID RAZR M
Posted 24 September 2013 - 11:09 PM
I have 4G/LTE problems, somewhere i broke my radio. It is this way on this ROM, every other, and STOCK. i have rsd'd, fastbooted, and more back to stock so many times, yet still the only way i can get 4G data is to change the radio band to 4G only. on LTE + CDMA/EVDO I am constantly connected to an eHRPD network. I thought maybe this was an APN issue, but i CANNOT seem to correct it. Any ideas? i have been into *#*#4636#*#* and i have heard you shouldn't do this if on verizon, but you have to understand on 4.2.2 it was the ONLY way to get LTE by switching under the Test Info. I get great 3G, around 250kBps download speeds, but i miss the 3mBps download speeds. i can have those speeds if i change the band, but then i can't receive calls, and texts are spotty. sometimes they come thru, sometimes they don't. Anyway, I am no noob, and have tried everything i can think of including flashing modem, and fsg via fastboot, then erasing modemst1 and modemst2, this should give a stock, unaltered radio.. but it doesn't. when i got the phone, new, it had the .66 4.1.2 firmware, and i have flashed .78, and .3 here recently, but no cigar. I have a lot of Android knowledge, so i should be able to try anything suggested. Thx in advance.
#2 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 25 September 2013 - 01:08 AM
I've seen this pop up before, no matter what you do you can't get signal.  The solution I've seen was just getting a new sim card.  When I've seen problems like this in the past, someone suggested a new sim card and it has always seemed to work out.
#3 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
Posted 25 September 2013 - 01:58 PM
i have a spare. i will activate it later and let you know.
#4 Joshuamink
Joshuamink
    xt907er
  • 92 posts
  • Twitter:@joshmink
  • LocationOHIO
Posted 25 September 2013 - 05:20 PM
you saved my rear end again, RikRong. funny, i tried everything, but that. i think the SIM controls APN settings and i think a couple of the APN Profiles got deleted somehow. Thanks again for the suggestion man. hope all is well.
  • neckchop and RikRong like this
#5 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 25 September 2013 - 07:07 PM
Haha, no problem.  All is well but I'll be spending the next four months getting a nice tan over here in the desert.
