Problems With Ics Leak
Posted 25 June 2012 - 04:34 AM
Posted 25 June 2012 - 04:44 AM
Posted 25 June 2012 - 05:02 AM
Posted 25 June 2012 - 05:09 AM
Sorry, but you can't go back to stock, unless you get lucky and someone leaks a tool that allows that to happen.How do i do a hard reset on this phone? Anh idea what day the updat will be hitting? And how can i put my phone back to stock so i can receive the update?
Backup any info you might need, then Goto System settings, privacy, factory data reset.
Personally I would also format internal storage and external storage.
Don't restore any apps that ran on GB onto your ICS install.
Posted 25 June 2012 - 06:11 AM
Posted 25 June 2012 - 06:15 AM
Posted 25 June 2012 - 06:39 AM
Either way, I (nobody) can help you unless we know which version you installed.
Posted 25 June 2012 - 06:55 AM
- ibolski likes this
Posted 25 June 2012 - 09:53 AM
Posted 25 June 2012 - 09:58 AM
Was your phone plugged in? I only ask because I had a phone behaving this way and it ended up being a damaged usb cable.
I was having this same problem and once I unplugged it from the wall charger, it worked just fine.
Posted 25 June 2012 - 10:00 AM
Posted 25 June 2012 - 02:20 PM
Posted 25 June 2012 - 09:09 PM
I did a reset and it seems to have helped for now.
Does'doing a factory reset clear all my current text? Just wondering because I cant afford to lose them atm.
Posted 25 June 2012 - 09:38 PM
Yes it doesDoes'doing a factory reset clear all my current text? Just wondering because I cant afford to lose them atm.
Posted 26 June 2012 - 06:08 AM
Posted 26 June 2012 - 04:00 PM
I use SMS Backup+ to automatically backup all of my text messages to my gmail account. It's free and works without thinking about it.
Posted 26 June 2012 - 05:06 PM
