Razr XT912 (Verizon) Can't access mobile data, call forwarding etc.
6 replies to this topic
#1 NoOpen
NoOpen
  • LocationAustralia
  • Current Device(s):Razr XT912
Posted 03 October 2013 - 10:31 PM
Hello I recently purchased a Razr XT912 Verizon for use with my Optus sim card in Australia. I managed to upgrade it to 4.1.2 JB fine then root it with "Dan Rosenberg's DROID RAZR 4.1 Jellybean exploit called 'RAZR Blade'" Call's and SMS work fine but mobile data does not either does call forwarding (In relation to extending ring time), When trying to do that it fails to call and gives me the message "Call forward is disabled outside the Verizon Wireless network".
Any help would be greatly appreciated
#2 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 04 October 2013 - 09:39 AM
Did you add in your GSM network correctly in the settings?
Donate? Click on signature :)
#3 NoOpen
NoOpen
  • LocationAustralia
Posted 05 October 2013 - 02:00 AM
Yes I have tried all 3 network settings and have clarified my APN settings are correct.
#4 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 05 October 2013 - 02:11 AM
I used my XT912 in NZ and Aus earlier this year. I remember once I didn't have mobile data and all I had to do was change a setting. I just can't remember where that setting was. I just remember that it was something extra that the Vodafone representative did not know they had to enter. Keep searching the internet and I'll have a look today.
Sent from my DROID RAZR using Tapatalk 4
#5 cmh714
Posted 13 October 2013 - 06:56 AM
You say you have the APN correct, but you can take a look here and see if there is something you havent tried. Optus has a few settings depending on the service you bought it appears.
#6 NoOpen
NoOpen
  • LocationAustralia
Posted 18 October 2013 - 03:26 PM
Yes tried all those and sadly no luck.
#7 NoOpen
NoOpen
  • LocationAustralia
Posted 10 November 2013 - 03:53 PM
Shameless bump, Still can't fix this problem tried every possible combination of APNs
