anyone using xt926 out of US having signal problem on 4.3 Rom, i used to use xt925 4.2 Roms which worked flawless but since 4.3, i am getting no signal 80% of time and the 20% of time so weak signal whether 2G or 3G (whether xt926 Rom or xt925 rom), the only Rom works ok is Probam for xt926, which is basicly PacMan, but the newer versions of PacMan having the same signal issue . i tried almost all 4.3 Roms and all of them having the signal issue unfortunately. thanks a lot in advance
