UPDATE:
I found a kernel panic message under /data/kernelpanics:
Type: SYSTEM_LAST_KMSG
Linux version 3.0.93-g01d4e4b (build@Prometheus-PC) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Aug 26 18:09:46 WST 2013
SERIAL : 0x1000201ebd2fb
HW_REV : 0x8300
] Notify: smsm init
] _smem_log_init: no static log or log_idx allocated
] _smem_log_init: no power log or log_idx allocated
] Unable to handle kernel paging request at virtual address 7ffffffc
] pgd = deab4000
] [7ffffffc] *pgd=00000000
] Internal error: Oops: 5 [#1] PREEMPT SMP
] Modules linked in: tcp_westwood cfg80211
] CPU: 0 Not tainted (3.0.93-g01d4e4b #1)
] PC is at memcpy+0x114/0x330
] LR is at wakelock_seq_start+0xb0/0xd4
] pc : [<c03a0a34>] lr : [<c01a83c0>] psr: 20000093
] sp : de393edc ip : 00000003 fp : deae5480
] r10: 00002000 r9 : e0237e00 r8 : 41b633d0
] r7 : dff8fe68 r6 : e0237e00 r5 : 20000013 r4 : 7fffffff
] r3 : 00000000 r2 : 00000054 r1 : 7ffffffc r0 : e0237c80
] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
] Control: 10c5787d Table: a53b406a DAC: 00000015
] Before flush cache...
] SP: 0xde393e5c:
] 3e5c 00000001 00000000 c0d6c700 e3efc9b3 00000002 c3e8c7b3 00000002 ffffffff
] 3e7c de393ec4 e0237e00 dff8fe68 41b633d0 c0801dec e0237c80 7ffffffc 00000054
] 3e9c 00000000 7fffffff 20000013 e0237e00 dff8fe68 41b633d0 e0237e00 00002000
] 3ebc deae5480 00000003 de393edc c01a83c0 c03a0a34 20000093 ffffffff 00000564
] 3edc e0237c80 7fffffff c01a83c0 00000000 000005b1 de393f08 c023594c de392000
] 3efc deae5480 de393f88 e0237e28 00000020 00000000 00000021 00000000 de393f88
] 3f1c c8ca8100 c8ca8148 c0235664 deae5480 de393f88 41b633d0 00002000 5f09db84
] 3f3c c025ada0 deae5480 41b633d0 de393f88 41b633d0 00002000 de392000 00000000
] R0: 0xe0237c00:
] 7c00 00000002 dfd23bc0 00000000 10002000 00000000 00009000 00001100 dfd473c0
] 7c20 0000000a 0000000a c0c76f50 00000001 00000000 00000000 00000000 e012263d
] 7c40 e012253c e0237ebc 00000000 dfbd3480 00000000 00000000 00000000 00000000
] 7c60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
] 7c80 7fffffff 00010001 dff8fe70 dff8fe70 00000000 00000000 00000000 00000000
] 7ca0 c0d6c700 c045b8f0 dff8fe00 ffffffff ffffffff 00000000 00000000 00000000
] 7cc0 00000000 00000000 00000000 00000500 dff8feb8 dff8feb8 00000007 c0c5ad00
] 7ce0 c0c5aae8 c0c5b790 deafd368 c0194964 00000000 00000000 00000000 00000000
] R6: 0xe0237d80:
] 7d80 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
] 7da0 00000000 00000000 00000000 00000000 ffffffff ffffffff ffffffff ffffffff
] 7dc0 ffffffff ffffffff 00000000 00000000 00000000 c00c8680 c00c86c0 c0c5ad00
] 7de0 c0c5aae8 c0c5b790 00000000 00000000 00000000 00000000 00000000 00000000
] 7e00 dfe83000 00001000 00000000 000005b1 00000000 00000000 00000000 00000000
] 7e20 00000000 00000000 00000000 00000000 e0237e30 e0237e30 de362f80 c08106b8
] 7e40 e0237c80 00000000 00000000 00000000 00000000 dfdc4740 00000007 c0c5ad00
] 7e60 c0c5aae8 c0c5b790 dfc322e8 c0194964 00000000 00000000 00000000 00000000
] R7: 0xdff8fde8:
] fde8 00000000 00000000 00000000 00000000 00000000 00000000 c8cf9008 e0649280
] fe08 e064dcc0 dffd6424 dffd3e0c e064dd00 c8c62540 c0c788d8 e06483c0 00000003
] fe28 00000007 00000000 00000000 00000001 00000000 dff8fe3c dff8fe3c 00000000
] fe48 00000000 00000000 00000000 00000000 00000000 00000000 dffd6478 dffd3e60
] fe68 7fffffff 00010001 dff8fe70 dff8fe70 00000000 00000000 00000000 00000000
] fe88 c0d6c700 c045b8f0 dff8fe00 ffffffff ffffffff 00000000 00000000 00000000
] fea8 00000000 00000000 00000000 00000500 dff8feb8 dff8feb8 c045c4a0 00000000
] fec8 dff8fec8 dff8fec8 00000000 00000000 00000101 00000000 00000002 00000000
] R9: 0xe0237d80:
] After flush cache...
] SP: 0xde393e5c:
] R0: 0xe0237c00:
] R6: 0xe0237d80:
] R7: 0xdff8fde8:
] R9: 0xe0237d80:
] Process ActivityManager (pid: 794, stack limit = 0xde3922f0)
] Code: e211c003 0affffc4 e3c11003 e35c0002 (e491e004)
] Kernel panic - not syncing: Fatal exception
] SMP: failed to stop secondary CPUs
] mbm_version=0x0000109b
] CPU type is ACPU PVS: Fast
] Timestamp = 129737.309
] Current Time = 01-02 12:02:17.309, Uptime = 22.105 seconds
] RAM: Elpida, S4 SDRAM, 1024 MB, MR5:0x03, MR6:0x00, MR7:0x00, MR8:0x18
Anyone have any ideas as to what this could mean?
