broken phone problems HELP please
10 replies to this topic
#1 bogginblazer
bogginblazer
  • 38 posts
Posted 17 October 2013 - 07:44 PM
ok sooo i broke my phone slamed it in the trunk of my gfs car.................. yes...... yes i was drunk.
but heres the issue i need the pics off the internal sd card. the phone screen is to far gone to use. so what can i do?
the phone turns on and powers up just the screen is gone.
i connect the phone to my computer it wont let me in because of the locked screen. it has pattern password.
any ideas are welcome. but i got some good news tho. i am now the owner of a brand new droid maxx :) so something good came out of this.
thanks a bunch for reading and any help i get.
#2 johnthehillbilly
Posted 17 October 2013 - 07:52 PM
First question.... did you have USB debugging enabled?.... if you did it will be way easier....
#3 bogginblazer
bogginblazer
  • 38 posts
Posted 17 October 2013 - 07:56 PM
umm no i did not. i never messed with the phone
#4 johnthehillbilly
Hmmmm....... you can use RSDlite or Matt's utility to fxz back to stock.... then you will be able to access the internal storage..... HD tappin' .... hillbilly style!!
#5 johnthehillbilly
Posted 17 October 2013 - 07:59 PM
Even with the screen broken, you can still access APFastboot (which is required for either method)
#6 bogginblazer
bogginblazer
  • 38 posts
Posted 17 October 2013 - 08:07 PM
when can i find out how to get in to fastboot and matt's program?
#7 johnthehillbilly
Posted 17 October 2013 - 08:14 PM
To get into fastboot.... you need to power off.... then hold volume up + volume down +power for a couple seconds..... then hit volume down two times.... then volume up once..... you should be in APFastboot mode....:)
#8 bogginblazer
bogginblazer
  • 38 posts
Posted 17 October 2013 - 08:21 PM
do u think safe mode would work?
#9 johnthehillbilly
Posted 17 October 2013 - 08:24 PM
It might..... I'm not 100% sure about that..... but if you do end up doing fxz (fastboot) you can also check out House of Moto ....
#10 bogginblazer
bogginblazer
  • 38 posts
Posted 17 October 2013 - 08:32 PM
thanks man but i gtg to bed now :( ill dl it tomorrow thanx for your help ill let you know if it works
#11 johnthehillbilly
Posted 17 October 2013 - 08:44 PM
No problem anytime:)
