Hey all,
Recently, I have been trying to build my own ROM (on the .211 kernel) from dhacker's CM9 OR AOKP ICS-leak source (either works, just need to learn one and I should be able to figure out the other). However, I have run into somewhat of a roadblock. After doing a good amount of reading, I have my environment setup and am running Ubuntu 10.04 through VirtualBox (with JDK 6 and Android SDK). I am successfully able to sync from the STS-DEV Team repository ( ) using the following command:
However, when i try to run the lunch command and select my option (full_spyder) to compile, I get a message saying the "Dependencies files were not found. Bailing out". I believe I have not synced everything I need, but am not sure as to what all the necessary components are. Any help would be greatly appreciated!
In addition, I can post the steps I take to help discover if that is the issue as well.
P.S. I have a Gtalk to make life easier if anyone is willing to lend a hand.
Building From Source
Spartanxxx10
, Jun 29 2012 09:39 AM
2 replies to this topic
Posted 29 June 2012 - 09:39 AM
Posted 18 July 2012 - 05:16 PM
I wish i could help you, i never have built and compiled a full rom using SDK but i have found by decompiling/recompiling apk's and themes that every single xml line has to point to a valid source weither an image or value if one little thing is missing or wrong it bails out like that. I would be very interested in helping you in any way as i would like to start building/compiling roms ect.
Don't take me too seriously, its only my opinion...
Posted 18 July 2012 - 05:29 PM
Does it fail out after that message or continue to work? I'm asking because I've seen the message and don't think its a big deal. On the CM build there is a getprebuilt script that needs to be run before a build attempt. On source you don't want the full spyder lunch menu BTW... you want to use the cm-spyder which if I'm not mistaken is menu option 9. Not sure when I'll be available tomorrow but we can catch up then if you still need a hand.
