Unresponsive Screen
Unresponsive touch screen
16 replies to this topic
#1 evocop
evocop
  • 60 posts
  • Twitter:floydaccess
Posted 23 October 2013 - 08:11 AM
Ok I made a rookie mistake and used Matts Utility for XT912 to completely restore my Razr M. I was stuck into a fastboot bootloop. I realized my mistake and used Matts Utility for XT907 to restore and my phone booted normally to the select language screen. I tried selecting English and pressing next and realized my screen was not responding to any touch. I pressed the power button and tried to power the phone off and still unresponsive to touch. I have told power and volume down and quickly hold volume keys to boot into selection for Fastboot, recovery ect and then quickly press power button to power phone off.
I downloaded the official FXZ and restored again using RSDLite. The flash was successful and the phone rebooted. Got to the select language screen and still unresponsive. Where to I go from here? am I screwed? I am afraid when I used the utility for the XT912 It changed something with the hardware responsible for handling touch recognition.
I have booted into recovery and tried factory reset. I tried clearing cache and resetting again and still no dice. Bootloader stayed unlocked through it all. Any Ideas.
#2 Someolddude
Someolddude
  • 426 posts
Posted 23 October 2013 - 12:11 PM
Does the screen work in recovery?
#3 evocop
evocop
  • 60 posts
Posted 23 October 2013 - 03:25 PM
No the screen will not work in recovery. I flashed Twrp via fastboot and can not navigate anywhere past the main TWRP screen. I can navigate in the stock recovery utilizing the volume controls and power button.
#4 Someolddude
Someolddude
  • 426 posts
Posted 23 October 2013 - 05:01 PM
You can install cwm recovery with Matt's utility then use adb to get into it and flash a new os in there and see what happens.
#5 lowvolt
lowvolt
  • 478 posts
Posted 23 October 2013 - 06:07 PM
Do you have any backed up Roms? If so flash CWM and flash a ROM. Even if you have to clean flash it. Then see if the touch screen works
Sent from my XT1060 using Tapatalk
  • evocop likes this
#6 evocop
evocop
  • 60 posts
Posted 24 October 2013 - 06:28 AM
Ok thank you guys. I do not have any backed up roms but I will download one to my ext sd card and give it a shot after I flash CWM through fastboot. Ill let you know.
#7 evocop
evocop
  • 60 posts
Posted 24 October 2013 - 01:32 PM
Well I downloaded Deadcalm rom and flashed. Booted to language screen and screen is unresponsive still. Is it done for?
#8 SamuriHL
  • 43,463 posts
Posted 24 October 2013 - 02:17 PM
Sounds like a badly timed hardware failure to me.  It may or may not be related to the improper flash.  Yes, these things can happen.
  • evocop likes this
#9 livinginkaos
Posted 24 October 2013 - 03:00 PM
I was thinking the same thing as you mentioned elsewhere. If the touch screen is dead in recovery chances are hardware, from what cause ??
Sent From My DEV X
  • evocop likes this
#10 Someolddude
Someolddude
  • 426 posts
Posted 24 October 2013 - 03:30 PM
One thing I found on Google is to remove the sim card and sd card after shutting it down and power it up to see what happens. Theory being they could be corrupt.
  • evocop likes this
#11 evocop
evocop
  • 60 posts
Posted 25 October 2013 - 12:00 AM
Well thank you all for the tips and help. I guess I am going to trash it or throw in the "play phone" bin for my 4 year old. Back to flashing and tweaking on my OG Razr! RIP Razr M!
#12 Someolddude
Someolddude
  • 426 posts
Posted 26 October 2013 - 03:43 AM
That's one way to go. I'd keep trying for a few reasons. The big one defeat isn't acceptable to me and most likely there is a solution you just need to figure out what it it's. Also if you do find the fix and share it you can help other people.I fell for you because I couldn't afford to get another phone if that happened to me.
#13 0n1wheel
0n1wheel
  • 11 posts
  • Twitter:0n1wheel
  • Current Device(s):Razr M
Posted 19 November 2013 - 12:07 PM
I have the same issue with the unresponsive touch screen. I think it's a hardware issue  :angry:
#14 Someolddude
Someolddude
  • 426 posts
Posted 19 November 2013 - 01:43 PM
Did you perhaps flash the wrong ROM? I did one time and had a none responsive screen. Just wiped reflashed and was good to go.
#15 0n1wheel
0n1wheel
  • 11 posts
  • Twitter:0n1wheel
Posted 22 November 2013 - 11:01 AM
No, my phone was working fine for weeks with a good rom. I got a replacement from verizon and accidentally did the update, not knowing the newest update would not allow root. Now I'm stuck with a bloated rom.
#16 evocop
evocop
  • 60 posts
Posted 03 January 2014 - 01:58 PM
Well folks, there is a fix for the problem I had and all thanks goes to an XDA member "
". Just follow this post ---->
I can not thank him enough. Make sure you give him all the credit and thanks!
#17 Someolddude
Someolddude
  • 426 posts
Posted 16 January 2014 - 06:23 PM
Cool
Also tagged with one or more of these keywords: Unresponsive touch screen
