Fun Fact... Tablet Mode Ui On Droid Razr!
Posted 01 July 2012 - 02:13 PM
If you're gonna play around with it you'll need root. The easiest method to use is a lcd density changer from the play store. Preferred one that allows a preview change.
Once the density is changed goto settings->display and adjust the font size to huge! Im finding it actually pretty useful...
- mugsy77 likes this
#2 Guest_BDH_*
Posted 01 July 2012 - 02:19 PM
Ok just as was found on the GNex.. forcing the LCD density on ics causes the device into Tablet mode. I'm currently set for 160 which is the lowest I can get to stick. Im using Apex launcher due to being able to adjust the home screen rows and columns. Ive not encountered a FC yet but there are quirks. Such as the menu button not doing anything from the home screen. Not everything is in full on tablet mode but it is switched from the stock Phone UI.
How is the Play Store acting?
Posted 01 July 2012 - 02:30 PM
#4 Guest_BDH_*
Posted 01 July 2012 - 02:35 PM
Seems to be fully functional. It happens to be one of the apps that does change to full tablet mode! I just used it to download chrome browers... worked just fine.
Nice! ROM Time! lol
Posted 01 July 2012 - 04:18 PM
You also lose every widget/icon on the homescreens, except for google search, and you also lose every icon except apps on the bottom access panel.
It would be amazing if someone was able to develop a ROM that worked perfectly at density 160 or less
Posted 01 July 2012 - 04:42 PM
#7 Guest_BDH_*
Posted 01 July 2012 - 05:16 PM
I just tried it on the Maxx, and although it does go into what is similar to a tablet mode, unfortunately, it doesn't work too well. Stock functions like pressing the menu button to bring up task manager don't work, and for that matter, no secondary function for the hard buttons work. I haven't tried it with a 3rd party launcher, however, the layout and UI of ICS compatible/stock apps are beautiful.
One is already in the works
- mugsy77, Torin_93 and jw0914 like this
Posted 01 July 2012 - 05:33 PM
Awesome
Posted 01 July 2012 - 05:41 PM
However, I did find a 3rd party launcher that works AMAZING with low densities on ICS, Apex Launcher (as long as you're rooted, and the PRO version offers more options).
I'm currently using density 185, and assumed it would work just as well as it had on GB, however due to the little blue box that encompasses the homescreen on ICS (not sure what the actual name for it is), the homescreen and app drawer don't resize properly (I'm assuming this has more to do with tweaking from Motorola than it does the actual ICS build). I went through and read a few launchers and Apex seemed like the best (I don't like the fact that GO Launcher is a memory hog), and since downloading it, it seems flawless. After I get my homescreens set up the way I want them, I'm gonna try 160 again and see what happens
Posted 01 July 2012 - 06:27 PM
Posted 01 July 2012 - 06:29 PM
#12 Guest_BDH_*
Posted 01 July 2012 - 07:37 PM
It's really smooth and fast! Some of the apps are a little wonky still but that can get worked out soon hopefully.
- Zierm likes this
Posted 01 July 2012 - 07:50 PM
Posted 01 July 2012 - 08:08 PM
First shots of a possible KOA TabletUI ROM
I like it. Would like to give it a try.
#15 Guest_BDH_*
Posted 01 July 2012 - 08:14 PM
It's far from done, although everything works, except Webtop and HDMI, data works like CM9 and AOKP because it has a CM9 base. I can still PM you the link if you want it though, I'm going to do a lot more work on it this week though if you want to wait.
Posted 01 July 2012 - 08:18 PM
Posted 03 July 2012 - 06:02 AM
If you want an extra tester, or whatnot I'll gladly play with it too.
Posted 17 July 2012 - 11:58 AM
Posted 06 September 2012 - 09:30 AM
I really like the look of this. i would definitely like to try/use something like this. i tried changing some settings around and got my phone looking good but then this morning i noticed that my phone(calling service itself) was not working! i had a call and all my phone just told me was that he couldnt open 'phone'
Posted 06 September 2012 - 04:13 PM
2 things, it only works on AOSP builds (with the build.prop edit) and the way it looks proper has no status bar on the top its on the bottom right. The apps drawer button on the bottom is not there as well as the soft keys being on the bottom left and things like the settings menu are double paned. I already tried this on our Razrs both stock and cm9, it doesn't work right. I'll attach proper screens.
Sent from my Nexus 7
