[Mod] Accurate Battery [1%] Razr - Ics Deodexed
#21
Posted 03 July 2012 - 02:18 AM
#22
Posted 03 July 2012 - 02:21 AM
Running the gradient on Arctic now. Works great, thanks!!!
Well spoke to soon i guess. When i charged it this morning it never showed 100%. The phone showed charged on the lockscreen even though the numbers only showed 97. Unplugged it wipe cache an dalvik an reflashed the mod. Rebooted an it showed 90%. Plugged it back up an the lockscreen showed charged again before 100%. I left it plugged up an it got to 99 an stopped. When i unplugged it 100 flashed for a second then back to 99.
Just wondering if that is normal?
#23
Posted 03 July 2012 - 04:05 AM
I believe that's normal as I've seen this with several battery mods. I also see a discrepancy between the lockscreen percentage and the battery mod and a battery drop as soon as i unplug.
#24
Posted 03 July 2012 - 04:57 AM
Ok cool, just wondering I haven't used a lot of these so just wanting to make sure i didn't do anything wrong.
#25
Posted 03 July 2012 - 07:45 AM
Thanks laxx! I'll give it a try tonight.I was able to replicate your issue this morning. I recreated the mod using the framework-res.apk from Black Widow ICS and reflashed, and the toggles are now back. Give it a shot with the new mod.
The force is strong with this RAZR
#26
Posted 03 July 2012 - 08:24 AM
can I flash any of these mods?
Thanks man.
#27 Guest_BDH_*
Posted 03 July 2012 - 08:37 AM
If I run the 211 deodexed and zipaligned from here
Thanks man.
Yes
#28
Posted 03 July 2012 - 08:55 AM
Arctic is already deodexed but, how did you flash this on your "non-safe" side? Arctic should have only been flashed with safe system ENABLED.
To answer your question though, yes this should flash right over Arctic ROM, just wipe cache and dalvik first.
My bad. Meant to say safe side. Thanks!
Sent from my pager using Tapatalk.
#29
Posted 03 July 2012 - 09:17 AM
#30
Posted 03 July 2012 - 02:52 PM
#31
Posted 03 July 2012 - 03:47 PM
I installed the gradient for BW ICS. When I charge the phone it flashes, back and forth, between 45% (green) and 50% (gradient blue). As I'm typing this, the gradient blue has gone up to 52%. Weird! What do you think?
I'll have to flash BW and try. That's shouldn't be happening.
#32
Posted 03 July 2012 - 04:28 PM
Right now its, 75% green, 80% gradient.I'll have to flash BW and try. That's shouldn't be happening.
andlaw is updating bw ics soon, so if you wanna wait and let me try it with the latest update, I will and get back to you.
#33
Posted 03 July 2012 - 04:39 PM
Let me know. I flashed bw but have to play to figure it out.
I only changed images so this sounds like a system issue.
We can compare notes...
#34
Posted 04 July 2012 - 06:42 AM
My bad...I forgot to update the XML file.
I've fixed and updated the links on the OP. You can download and flash again.
#35
Posted 04 July 2012 - 10:08 AM
#36
Posted 04 July 2012 - 10:51 AM
#37
Posted 04 July 2012 - 11:01 AM
Running Eclipse Razr ICS v1.1 flashed the gradient battey mod for Eclipse today....at 43% plugged phone into charger it flashes 30% green/43% blue gradient. lol
Thanks for the heads up. I updated the xml file and tested it and it works properly now.
I updated the OP. Download and flash again and it should work as intended
#38
Posted 04 July 2012 - 11:05 AM
I'll release soon (after my thorough testing)
#39
Posted 04 July 2012 - 11:33 AM
- spikefloyd and rickw like this
#40
Posted 04 July 2012 - 11:44 AM
Will do!!! Ty
