Cant mount /osh
1 reply to this topic
#1 kvjn777
kvjn777
  • Google+:lithium.kvjn
  • Current Device(s):Droid Razr XT912
Posted 31 October 2013 - 04:54 AM
Ive been trying for days on how to fix this. i I open safestrap(3.63) go into boot options and select rom slot-1.
System Partittion Size is 700mb
Data Partition Size is 2000mb
Cache Partition Size is 300mb
When I touch Create ROM slot
It pops up creating ROM slot.
Above has Updating partition details.......
E:Unable to mount /osh
Can anyone help me?
#2 aaron_escoto
aaron_escoto
  • Current Device(s):Droid Razr Maxx XT912
Posted 01 November 2013 - 07:44 AM
I had the same problem with my XT912, I looked everywhere I couldn't find anything specific about the "E:Unable to mount /osh".  It was driving me crazy.
I ended up flashing the stock ROM using RSD Lite, and did a factory restore to clear all data, this time I used the Safestrap 3.50 instead of the latest one like I did the first time.... same error message. It was only until I uninstalled SS 3.50 and installed SS 3.11 was I finally able to flash a custom ROM with no problem. Also, ensure you have a proper root.
Hopefully this helps.
  • jjapol likes this
