Holo Launcher - Stuck
Posted 05 November 2013 - 08:05 PM
Posted 06 November 2013 - 04:11 AM
I can't access the launcher settings anymore. I set it so I could open the menu with two fingers swipe up, but it's not working. The menu just flashes briefly then goes away. I tried clearing default but nothing. I am trying to avoid starting over because I have customized icons and folders. Is there any other way to get to the menu settings?
you should be able to get to the menu settings by swiping just one finger up. if not, then a suggestion would be to install another launcher, and see if that launcher allows you to copy the format from Holo (many do nowadays). otherwise, you'll have to clear data for the app.
ROM: OSE KitKat 4.4.2
Posted 20 November 2013 - 01:06 PM
