I just downloaded razrbootstrap.apk and the cwm file to go along with it. When I used razrbootstrap to enter recovery and install the cwm file with it, it said it was successful. When I rebooted, it gave me an encryption unsuccessful message and now I can't reset my phone without it coming back to it. What do I do? Thank you in advance!
Stuck at encryption unsuccessful
aever
, Nov 05 2013 10:16 PM
2 replies to this topic
Posted 05 November 2013 - 10:16 PM
Posted 06 November 2013 - 04:15 AM
Well.... to start, we need to know what device you are using.... chances are tho you will need to FXZ back to stock, and start over without using razrbootstrap
"The force is strong with this one..."
Posted 06 November 2013 - 06:12 AM
Bootstrap recovery is not compatible with JB. So yes, you will need to use the FXZ and repair your phone and you will lose your data partition in the process since it's now corrupt. Safestrap is the only way to move forward under JB.
- johnthehillbilly and livinginkaos like this
