Keeping The Screen Light On (And Unlocked)
Posted 03 July 2012 - 12:06 PM
What I need is something that will block the lockscreen function on the phone, and keep the screen unlocked and the backlight on for infinite duration. Because I have corporate email, the screen forces a lock when the backlight times out at two minutes (or 5, or whatever you set it to). What I want is to keep the screen on and unlocked when the phone sits on my desk at work connected to the charger, and when it is docked in the (non-Morotola) car kit (from ProclipUSA). If I can toggle between "infinite" and "2 minutes" the app would be perfect.
There are a lot of screen timeout apps at the Play store, but they usually keep the screen on when a particular app is running. Kill the app and the screen locks. That's why "Screen Timeout Widget" was perfect.
Anyone with any ideas?
Posted 03 July 2012 - 04:13 PM
Posted 03 July 2012 - 04:31 PM
#4 Guest_BDH_*
Posted 07 July 2012 - 11:16 PM
This will keep your screen on as long as the phone is plugged in.
Posted 08 July 2012 - 09:12 AM
#6 Guest_BDH_*
Posted 08 July 2012 - 10:05 AM
That didn't work for me in the car dock, plugged into the cigarette lighter running ICS.
Well it works, don't know what's wrong with your phone but it works on 99% of the other phones.
Posted 08 July 2012 - 10:22 AM
Posted 08 July 2012 - 12:02 PM
It used to work on mine before ICS. It might be because I had disabled the car dock app. All I know is I have that enabled and when using Google Navigation, the screen kept going black every 5 minutes.Well it works, don't know what's wrong with your phone but it works on 99% of the other phones.
#9 Guest_BDH_*
Posted 08 July 2012 - 12:18 PM
With that setting though it should keep the screen on regardless of what app you're running, as long as the phone is charging. That's what it's supposed to do at least.
Posted 09 July 2012 - 08:02 AM
What I'm really hoping to accomplish is to keep the screen illuminated when docked/powered in a non-MOT car kit and connected to the car kit via Bluetooth. I'm currently trying the "Car Kit" app, but that doesn't keep ithe screen on, even though it has a check box that allegedly enables that functionality.
Posted 09 July 2012 - 08:37 AM
Posted 09 July 2012 - 08:49 AM
Posted 09 July 2012 - 08:57 AM
I got it because while browsing web pages, unless I started touching the screen, it would time out. Since most people hold the phone at an angle when using it, Screebl senses the angle it's being held at and if it's past a certain degree from laying flat, it will keep the screen on.
Posted 11 July 2012 - 01:32 AM
