Custom Governors/schedulers
Posted 03 July 2012 - 12:35 PM
Also is there a way to get SIO or NOOP on the RAZR?
I am new to the RAZR, coming from a DX and it seems we are just scratching the surface when it come to the perfomance of the RAZR.
Any info would be greatly appreciated, thanks in advance!
Posted 03 July 2012 - 05:38 PM
Posted 03 July 2012 - 06:06 PM
Posted 03 July 2012 - 07:36 PM
@ ncwildcat - How did you get noop? I didn't see it on stock GB or ICS, and I have used a couple custom ROMS and haven't seen it. I use ROM Toolbox for my system settings FYI.
- mikeramos90 likes this
Posted 04 July 2012 - 05:17 AM
Posted 04 July 2012 - 05:50 AM
- ADIDAS likes this
Posted 04 July 2012 - 06:03 AM
I set Noop/hotplug using No-Frills CPU Control which is free
Just tried it out, will see if this works any better. Are you getting better performance?
Posted 04 July 2012 - 06:44 AM
They can effect the I/O operations, mainly the efficiency of memory and disk usage. The razr uses DEADLINE by default, but SIO and NOOP is much faster (utilizes less CPU) and manages battery usage better.
Thanks man, appreciate the answer
Posted 04 July 2012 - 07:29 AM
edit: Answered in other thread
Posted 04 July 2012 - 07:56 AM
I used Rom Toolbox actually.
Posted 04 July 2012 - 09:09 AM
Yeah I am an idiot, lol. I didn't see noop in the stock ROM's so I forgot to check in the custom ones. I am using noop now. LOL
I am really interested in getting Smartass and Boostedass though, but I don't know how much of an improvement they would be over hotplug. On the DroidX the combo of BoostedassV2 and SIO seemed to net the most improvement.
I am scoring a little over 3300 in Quadrant right now at stock clock speeds so I guess I can't complain. Liquid 1.5 ICS and some of my own custom tweaks and I am flying!
Posted 04 July 2012 - 12:48 PM
Posted 04 July 2012 - 01:56 PM
Haven't had any performance issues, but I'm noticing that the battery seems a little better.
Posted 06 July 2012 - 06:38 AM
whoops I thought I typed what it was. They just got some kernel moduals to load into the 3.0.8 kernel. Smartass governer is in there.
Posted 06 July 2012 - 12:33 PM
Anyone know how to get the kernel modules to work? I installed the zip at the link above but not sure how to activate the Smartass V2 governor. I do not have 10 post at XDA to ask this question.
Posted 06 July 2012 - 12:38 PM
Looks like you have to use terminal to manually add the commands from the 2nd post over there.
Posted 06 July 2012 - 12:51 PM
I am rocking InteractiveX right now, Try the others when I get home tonight!
Posted 06 July 2012 - 12:57 PM
Or you can just flash the 2 files here:
I did install those two but just not sure how to get any of the governors to show up. How did you pick interactiveX?
Posted 06 July 2012 - 12:58 PM
Posted 06 July 2012 - 01:02 PM
How are you getting these to survive reboot?
Per Whirleyes at XDA "you have to use init.d or custom init to have it persist".....Not sure how that's done but that's what he says....lol
