Custom Governors/schedulers
#21
Posted 06 July 2012 - 01:02 PM
#22
Posted 06 July 2012 - 01:06 PM
Yeah that's why I was curious since the I haven't really seen init.d on the Razr like I had with my X.Per Whirleyes at XDA "you have to use init.d or custom init to have it persist".....Not sure how that's done but that's what he says....lol
I'll have to mess with it
#23
Posted 06 July 2012 - 01:08 PM
I noticed that on the module. I've loaded govs manually in terminal before, so that's no big deal. They showed up in ROM Toolbox without loading them manually, so that surprised meI ran them through init.d but the flashable scripts don't work for that. He doesn't have the permissions set right for the 90module file. You could also use rom tool box to run on boot with them, but the governer wouldn't be there for the toolbox to enable it.
#24
Posted 06 July 2012 - 01:09 PM
I'm running .214 on simplexrom 1.0.1,Yeah that's why I was curious since the I haven't really seen init.d on the Razr like I had with my X.
It has init.d support, and that file is located at \etc\init.d\
the file the flashable zips drop off in there is 90module and it should have permissions set to rwxrwxrwx, but the flashable zip only set's it to rw-r--r--, so you just mount system as read/write, and chmod 90module to 777, and it'll run on bootup everytime.
<-- I'm not a teacher, but that's how I did it.
They won't persist through reboot though.I noticed that on the module. I've loaded govs manually in terminal before, so that's no big deal. They showed up in ROM Toolbox without loading them manually, so that surprised me
#25
Posted 06 July 2012 - 01:13 PM
#26
Posted 06 July 2012 - 01:16 PM
#27
Posted 06 July 2012 - 01:21 PM
#28
Posted 06 July 2012 - 01:26 PM
InteractiveX contains the hotplug tweak that allows one CPU to sleep while the screen is off so that one will have the best battery life most likely
#29
Posted 06 July 2012 - 01:28 PM
And I can already tell after running about 1 1/2 hours that InteractiveX will extend battery life. Battery drain isn't as steep and the CPU doesn't spike to 1200 every 3-4 seconds like it did with hotplug. Can't wait to try SmartassV2 I had great results with it on my DX.
I've been running it since about 11 a.m. est. I'm on an og razr with juice defender in a 4g area, and I just hit 79% at 5:43p.m. est. With moderate use. Which is great compared to just stock ics.
#30
Posted 06 July 2012 - 01:51 PM
Sent from my Droid Razr
#31
Posted 06 July 2012 - 02:04 PM
sent from my Razr Maxx running Eclipse ICS
#32
Posted 06 July 2012 - 02:14 PM
So far I noticed that using smartass v2 really hurts your performance when using apps, i think it forces the cpu to stay at 300 which is a great battery saving concept but scrolling is painful lol
With CPU spy, I have shown a good amount of time on other frequencies and not just 300. Scrolling is pretty normal for me. But my battery has shown improvement in the really short time I've been using it.Edit: my bad
#33
Posted 06 July 2012 - 02:35 PM
#34
Posted 06 July 2012 - 05:29 PM
#35
Posted 06 July 2012 - 06:03 PM
#36
Posted 07 July 2012 - 02:47 PM
I have the feeling its just a coincidence though.
#37
Posted 07 July 2012 - 05:53 PM
#38
Posted 07 July 2012 - 10:50 PM
Since i've started using interactivex i've had times my screen wouldnt come on at all and I needed to reboot. Anyone else?
Same thing happened to me. Gonna try hotplugx and noop and see how it goes.
#39
Posted 08 July 2012 - 04:47 AM
Ditto. It happened to me twice so I switched to hotplugx and no issues in the last 12 hours.
Crossing my fingers.
#40
Posted 08 July 2012 - 07:28 AM
