I restarted my
and now there is a message in my system tray that the phone is trying to prepare my SD and checking for errors. I have pulled the SD card multiple times and nothing. It just shows like my SD card is wiped. When I access it through I can see all the files. Also when I put the card into another phone I can access all the files. I put the SD card into another phone and saved everything to my computer. Then reformatted the card and transfered all the files back. Everything worked fine. This morning I did a Titanium Back up of my and TWRP back up in case the new update auto installed. Now I have the same problem. Anyone know what is going on 794.22KB 15 downloads 255.68KB 15 downloadsExternal SD Problem RAZR HD MAXX
Posted 08 November 2013 - 09:56 AM
Posted 08 November 2013 - 11:53 AM
I had a similar issue which tuned out to be my sdcard was starting to fail.
Posted 08 November 2013 - 11:55 AM
That's what I 'm thinking. I just don't want to buy a new one and the same thing happens.
Posted 08 November 2013 - 06:50 PM
Since I have a bunch, I was able to test other cards out. For me, when it looked like it saved a file, nothing was actually written to disk but the phone and the apps thought everything was ok. My issue was a little different, I couldnt format the card or actually delete any files, although it appeared that they were deleted.
I emailed SanDisk and they replaced my card since it was only 8 months old
Posted 09 November 2013 - 05:06 AM
