Hi, I have a razr maxx hd with an unlocked bootloader, it is rooted and running the nexesque rom. I use Bluetooth in the car for calls and it works great, connects automatically, which I love. I recently set up the Bluetooth connection with my pc to print some files. Is there a way to not have the phone connect automatically to the pc all the time... short of turning off the Bluetooth or unpairing it? In the past I've had phones that had an option for turning off the auto connect feature on one paired device, but allowing auto connect for another device. Is this possible on the razr maxx hd? If it is, I can't seem to find the setting. Not a big issue, but would be great if possible if anyone has the answer. Thanks in advance for any help.
Basic bluetooth question
tmord1
, Nov 11 2013 10:02 AM
No replies to this topic
