hi, i thank you all , this forum has helped me alot, since i found it, first time i post, i have a xt907 and it locked up on me, that morning i was stressed so i just grabbed the torq and took it apart to do a bettery reset, not knowing any better, , AND now all i get is green light and no matter combination of buttons and time ,nothing works, i get a green light when i plug it in, doesnt blink just constant, thats about it, i cant enter boot menu or anything, greatly appreciated on any info or help beforehand dhave a great day!!
hard brick. constant green light when connected
Posted 13 November 2013 - 02:04 PM
Posted 13 November 2013 - 02:08 PM
are you sure you put it back correctly?
- Someolddude likes this
sig made by
Rinkle McBally
Posted 13 November 2013 - 02:23 PM
yes. totally... how complicated can it be, this cellphone inside has about 8 multiconnectors, i only took one off, left the screen conected. dissconected battery, and reconected it after 10 minutes. trust me this phone inside is not complicated, they just made everything so nice inside that there is nothing to leave disconected. when you close it up it has tabs that put pressure on the connectors to make sure they dont dissconect when we drop it.
Posted 13 November 2013 - 02:50 PM
I assume you tried power and volume down for 10 seconds
sig made by
Rinkle McBally
Posted 13 November 2013 - 07:26 PM
hmm methinks you might have borked something when you torq'd it....
Posted 14 November 2013 - 05:36 AM
did not put torq on them bots, just turned them till they touched not tight. i have tried all button combos, for dif time on each combo
Posted 14 November 2013 - 08:19 PM
possibility for nyone to give me a hand or point me in the right direction to who ask questions to for this product
Posted 15 November 2013 - 06:55 AM
please!
Posted 15 November 2013 - 07:29 AM
not sure what a torq is... and also not sure why taking battery off... the hard way. is the phone functional at all? or just give you green full screen light or just the little LED light.. if its just LED light than you might of even tho you saying not but you might of not connected screen properly...
Posted 15 November 2013 - 01:07 PM
hope you have insurance - sounds like this badboy might be dead.
Posted 16 November 2013 - 04:10 AM
I would take it back apart and if needed use a magnifying glass to inspect it. A ribbin can crack or a conection can be not fully seated or a wire could have gotten pinched and damaged. Next time go to google before you go to you tool box.
Posted 16 November 2013 - 08:46 AM
that swhat im about to do, thing is someolguy i am in the middle of panama in the mountain and had rent machinery i was delivering and had the clients number in that phone, too bad i had my toolbox right next to me,
Posted 17 November 2013 - 08:54 PM
dude your phone book should be backed up on google account... so if you need the number look it up on google gmail i think could work.. or the phone bill..
