success!!!!!  Mattlgroff you are the man thank you!
STEPS:
1: get the 1.7 utility and the blur version.zip place it on sd card. If phone is bricked prior to putting this on sd card (which i assume it is) get a micro sdcard to usb reader for your comp.
2: once you realize your phone is not going to boot... go ahead and hold down power button+ vol down... wait till screen flashes
3: after screen flashes hold all three buttons; power+ vol down+ vol up
4: AP Fastboot mode and do step two in the utility to unbrick
5: Reboot and repeat steps 2&3
6: Go back into AP fastboot mode and run option 2 of the utility
7: Reboot phone (again) follow same steps but this time reboot into recovery mode
8: Wipe Data
9: Flash the .zip file that is on sd card
10: If install fails first time let your heart skip a beat and hit reboot system (chances are your boot wont get very far since you are still bricked)
11: Go ahead and repeat step 2 and reboot back into recovery mode....
12: Reflash .zip from sd card this will take a while but it worked for me now i am back on system .211
these steps are in no way perfectly written but are good for people that have done their research and know a little about android flashing
Edit: Changed Step 6 to say Option 2 instead of 1. - iDroidGuy
How To Get To Stock After A Softbrick
callahanx
, Jul 05 2012 05:27 PM
3 replies to this topic
Posted 05 July 2012 - 05:27 PM
Posted 05 July 2012 - 05:41 PM
Option 2, not Option 1
Option 1 will throw errors at them
@Step 6
@Step 6
- Aliceics likes this
Posted 05 July 2012 - 06:44 PM
Thanks for this (:
Posted 06 July 2012 - 05:01 AM
Thank you ha told you they weren't perfect but i needed somewhere to jot these down after I had to go through this process. But it seems to almost work as a fastboot file method... with obvious differences. Thank you for the help
