[ROM] SlimKat Alpha Official XT925/XT926 [4.4][11/18/13]
Posted 17 November 2013 - 09:52 PM
- JJT211, BionicMan69, jtommyj and 1 other like this
Posted 17 November 2013 - 09:54 PM
reserved for future use
Posted 18 November 2013 - 06:25 AM
Woot first !!! And flashing now brb with thoughts/opinion lol oh yes addons link gives 404
Posted 18 November 2013 - 11:46 AM
I have only one issue. Why the cell signal is empty. I make and receve calls normally but I can't see the signal power.
Thanks a lot.
Posted 18 November 2013 - 02:08 PM
I had lost my device but this rom saved my life. My xt926 is back to life.
Thanks a lot.
I had to disable / enable data to get the bars to show and when they did they showed lower than actual signal compared to dBm just a kink I'm sure , this dev has done a great job with this ROM
Posted 19 November 2013 - 05:17 AM
Not a critique, just a question. The Quadrant score on this ROM (my first 4.4 install) was quite low - 4100. I'm running OSE as a daily driver and hit 5200 and above. Is this normal for this ROM? I've heard 4.4 had a ton of under-the-hood changes, so I expected more "speed". I may have misinterpreted the benefits.
Proud father of a US Marine
Posted 20 November 2013 - 06:56 AM
Awesome! Flashed and everything is working fine, except video playback for me, which I can live without for a bit. Cool to see 4.4 on a device left at 4.1.2.
Posted 20 November 2013 - 11:21 AM
Loving it so far just thought I'd leave some feedback seems light weight and good on speed for me (haent ran any tests per say) been running this ROM for almost 2 days and only thing not working for me (as mentioned) is video playback. Thanks for all the work your putting in to this dude.
Edit: I didn't think that my hangouts video would work but I can confirm it works flawlessly!
Edited by rzrtm, 21 November 2013 - 12:35 PM.
Posted 20 November 2013 - 08:54 PM
I'm glad that I wasn't the only one who noticed Netflix and YouTube weren't working...
Posted 20 November 2013 - 10:30 PM
Posted 21 November 2013 - 03:00 AM
cool that you tube is fixed I couldn't wait to listen to "what does the fox say".....um any chance you know why your addons link labled (here) gives a 404 ??
Posted 23 November 2013 - 06:16 AM
I played with this ROM all day yesterday before dropping back to OSE 4.3.1. Here are the issues I had with it:
1) Some apps had issues with the external SDCard. Some didn't recognize it. Others could read it, but not write it.
2) When I started Google Maps navigation, I got a crackling/static sound from the speakers. Turning down the volume would not stop it, only a reboot. Ditto with music apps.
3) Camera app didn't show up in the list of apps. I used QuickPic to access the camera function, but the camera wouldn't work.
4) Handcent had issues with showing duplicate SMS messages so I had to switch to SMS Pro which worked fine. Apparently, this is a known issue with Handcent running on KitKat.
5) I got FCs from a couple of apps.
Posted 23 November 2013 - 08:56 PM
That's $#!+ty I didn't have any of these issues. I was worried camera wouldn't work because of video but I've had no issues or fc's.
Edit: alright dude I take back what I said on SDcard issues.. Woke up this morning to tibu not writing to SDcard!
Edited by rzrtm, 24 November 2013 - 02:35 PM.
