Aosp Roms?
Posted 06 July 2012 - 05:27 PM
Posted 06 July 2012 - 05:31 PM
The true AOSP roms are great, but HDMI and web top don't work (could be a deal breaker for some). Also, there are data drops, but you can usually get it back by toggling GSM, then LTE/GSM CDMA or whatever it is lol. Worst case scenario is you have to reboot
Posted 06 July 2012 - 05:51 PM
I can't even find the "true" AOSP ROMs lol. The three you mentioned are all pretty far from Vanilla, but I guess I'll deal with it. Thank you!Simplex, Eclipse and Black Widow are Blur based roms with Blur removed and AOSP added. Everything works.
Posted 06 July 2012 - 06:06 PM
Sent from my get n7000 using Tapatalk 2
Posted 06 July 2012 - 06:18 PM
Posted 06 July 2012 - 07:44 PM
True. I listed "problem free" ones lol.I can't even find the "true" AOSP ROMs lol. The three you mentioned are all pretty far from Vanilla, but I guess I'll deal with it. Thank you!
As said before, Droid hive has vanilla aosp roms, but they have the usual issues
#7 Guest_BDH_*
Posted 06 July 2012 - 07:50 PM
KOA ROM (CM9) or KOA AOKP, both are non-themed (just tweaked and modded).
KOA ROM (CM9):
KOA AOKP:
Posted 07 July 2012 - 05:38 AM
Posted 07 July 2012 - 05:41 AM
Pretty sure they're working in KOADoes anyone know which AOSP rooms "google now" is working on? Saw an article that the RAZR can run it but only on AOSP roms.
Posted 07 July 2012 - 05:42 AM
Posted 07 July 2012 - 01:08 PM
Posted 07 July 2012 - 02:35 PM
The ROM looks perfect but I can't find a list of bugs that it has on the RAZR and it looks like you need to be on an earlier ICS leak to use it. I am on 211. Any tips or anything?Try liquidICS 1.5 over on rootzwiki. Super smooth, and the best battery of any ROM for razr. (At least for me). Same problem with Google now though, text works fine, but no voice search.
Posted 07 July 2012 - 03:06 PM
Posted 07 July 2012 - 03:08 PM
About to install. This will be my first custom ROM on this phone. Wish me luck lolAny ICS version will work. I ran it on 211 with no problem. Data didn't always come up right away on boot, but if I just let it sit for a minute, it came up. Now I'm running it on 211 with the 214 kernel, and its still going great.
Posted 07 July 2012 - 03:12 PM
Liquid was very smooth. I didn't like how slow my wifi was to connect though. I was on the 211 kernel though at the time, but not sure if that would make a difference now. I hope they upgrade to 1.6 and also upgrade the wifi modules to the ones recently released in the ics source like KOA rom has.
Posted 07 July 2012 - 03:45 PM
Posted 07 July 2012 - 06:02 PM
