[Recovery] Clockworkmod Recovery Touch 5.8.4.5
#1 Guest_hacker812c_*
Posted 07 July 2012 - 04:44 AM
The base used in this Recovery is the Samsung Galaxy S3 CWM Touch
This recovery is compatible and fully tested with Razr ICS OTA
This recovery is compatible and fully tested with Razr XT910 and XT912
This recovery is compatible and fully tested on Droid Razr Maxx XT912
This recovery is compatible and fully tested with ICS Roms 4.0.3 and 4.0.4
This recovery is fully tested on roms custom created with Safestrap
The buttons and volume vol - and vol + this buttons are working perfectly
The buttons search and back on touch screen are working perfectly
The file system of this recovery is edited and tested [recovery.fstab]
For Razr XT912 i confirmed this release is running perfect, perfect install and working
For Razr XT912 now use CWM Touch or use Safestrap 2.0
For Razr XT912 uninstall Safestrap app and remove current recovery before installing CWM Touch Recovery
For confirmation see the post of HexBug... Thanks for participate HexBug
[Razr xt910 using Bootstrap BootMenu]
***do not install or uninstall hjack and BootMenu first.***
***Boot Menu is Amazing System you do not need my recovery***
[Razr XT912 uninstall using Safestrap]
***If currently using safestrap, must be in primary rom aka safe system prior to completing the following steps.
After confirmation of being in primary location you must uninstall current safestrap recovery from safestrap app before installing CWM Touch Recovery***
[Credits] XCellPhoneSalesRep My Big Friend
[Others Credits]
Hansheck - By working hard to correct the Boot
nitroglycerine33 - At work with Bootstrap Original
JYDaddy - For the original work on Recoverys
Hacker812c - Modification of scripts / exploits internal
Hacker812c - Amendment of recovery Internal / application testing
Hexbug - Thanks for testing on Razr Verizon XT912
XCellPhoneSalesRep - Thanks for help me and tests the Recovery on XT912
ClockworkMod is considered by many the best recovery system in place for android.
ClockworkMod Touch is an advanced recovery feature that incorporates the touch screen.
This tutorial including Root, ClockworkMod Touch and CWM were tested without error on my Razr
This tutorial is fully tested by other users Razr on Brazil
With CWM you can quickly recover your rom, reinstall updates, etc ...
[Setup]
1. Make the root of the device
2. Install RazrTouch5845.apk
3. Open the application that you installed and click to install the recovery
4. Now you have the best recovery system CWM ClockworkMod
5. Click "Reboot Touch CWM" and restart the device to go into recovery
6. Click on "Backup and restore" and "backup" to create your backup android
7. Install ROM MANAGER the download is free on Google Play
7. After completely restart the phone install ROM MANAGER and install
8. Now you see the your backups on /sdcard-ext/clockworkmod/backup
9. Now you can install the new Custom roms
10. After install your new rom install again Clockworkmod Touch 5.8.4.5
Now we have CWM 5.8.4.5 Touch
This recovery is based on the latest system rom manager clockworkmod.com
[ROOT]
[Download CWM Touch 5.8.4.5] APK
ROM MANAGER 5.0.0.7 free download on Google Play or Appbrain
[BUSYBOX PRO]
[THANKS]
If you have a little time press the THANKS, thanks.
[RESULTS]
This release does not cause brick ...
This release is based on Samsung Galaxy S3 Recovery [Clockworkmod.com]
This recovery was fully edited and tested for some users...
Compiled the apk and modified the recovery procedure...
The product is stable and tested in our Razr for some users...
The base used is the Recovery of the Samsung Galaxy S3
After testing the razr did not occur any error or failure.
Jesus is the secret of my success!
- etrorteepe and wayneh38 like this
Posted 07 July 2012 - 05:48 AM
#3 Guest_hacker812c_*
Posted 07 July 2012 - 06:42 AM
Thanks for reply Hexbug...
Thanks for participate...
I receive two confirmations of Razr xt912 and droid razr maxx...
This release incorpore the ultimate tecnology of clockworkmod...
This release is the latest version of clockworkmod...
This compatibilily is possible what all ports is updates...
Adbd, mke2fs, parted, recovery, sdparted, tunef2s all updated for this version...
God bless you.
Posted 07 July 2012 - 06:50 AM
#5 Guest_hacker812c_*
Posted 07 July 2012 - 06:54 AM
sorry for duplicate post. i understand the importance of this information for two forums...
Posted 07 July 2012 - 07:07 AM
Posted 07 July 2012 - 07:28 AM
Posted 07 July 2012 - 07:36 AM
My only suggestion. Remove some of the -no's upon making a selection.
I'll leave feedback after my install of a current as aokp is complete and tested.
Thanks again!
Edit: I'm having the same issue as i did before with bootstrap. I tried with 2 different roms and get the error message: can't connect to camera.I'm running the latest leak and tried dhackers latest aokp nightly and the latest koa aokp
Edited by superrelaxx, 08 July 2012 - 03:56 PM.
#9 Guest_hacker812c_*
Posted 07 July 2012 - 08:34 AM
i work on new release...
Posted 07 July 2012 - 09:41 AM
As a fan of bootstrap, I like it. Thank you.
Thanks again!Edit: I'm having the same issue as i did before with bootstrap. I tried with 2 different roms and get the error message: can't connect to camera.I'm running the latest leak and tried dhackers latest aokp nightly and the latest koa aokp
Thanks for the input. If you have time and are willing it might be interesting to see if a NON- Cm9 or AOKP rom work correctly. IE something like Black Widow or Artic that is based off the Moto build just removing bloat, deodexed, zipaligned....etc and there other tweaks
Posted 07 July 2012 - 11:10 AM
No problem. I have a dummy phone that i experiment with. I'll flash several and post my results.
#12 Guest_hacker812c_*
Posted 07 July 2012 - 01:20 PM
installed and works great!
thanks for participate and your feedback...
Posted 07 July 2012 - 02:12 PM
I'll give some more feedback tomorrow.
#14 Guest_hacker812c_*
Posted 07 July 2012 - 02:45 PM
remember you need uninstall any old system recover ... safestrap or bootmenu
if you use safestrap uninstall first completely
if you use bootmenu unsintall hjack and system first and only after uninstall you install cwm touch
if you use any system of dual boot or control boot you uninstall first for correctly run
Thanks for help me in this project
God bless you
Posted 08 July 2012 - 09:31 AM
thanks ...
God bless you
I had uninstalled safestrap prior to installing CWM.
I RSD'd back to 181 and loaded a fresh install of 211, upgraded to 214, re-gained root, installed CWM5.8.4.5, then flashed ArcticRom214rv1.
I'll run it for awhile and post some feedback.
Update: I bricked too. How do I get back into CWM? What are the key strokes?
Posted 08 July 2012 - 11:29 AM
Wait!!! I flashed arctic 214 r1 and bricked!!!!!
Posted 11 July 2012 - 03:06 AM
This doesn't sound good. And no response since the 8th?
Posted 11 July 2012 - 03:15 AM
Posted 28 July 2012 - 12:18 PM
Posted 28 July 2012 - 12:55 PM
