Ics Leak Battery/charging Issues
darkspector
, Jul 09 2012 12:21 PM
7 replies to this topic
Posted 09 July 2012 - 12:21 PM
I've read that .75 and .79 have battery/charging issues. When my phone dies it won't pull a charge, if I leave it plugged in enough it might decide to get enough juice to turn on, and charging really starts when it gets to the lock screen. Will reflashing my phone with a new ROM fix this or do I need to be on a different leak?
Thanks,
Chris
Sorry if this has been posted but I couldn't find the info anywhere.
Thanks,
Chris
Posted 09 July 2012 - 12:49 PM
You're still on the .79 leaks? The official ICS came out a week or 2 ago, definitely get on them ! Fastboot to stock GB and take the official OTA would be the simplest way in my opinion.
- Wes53177 likes this
Posted 09 July 2012 - 01:19 PM
Yeah, why not just go to 214?
Posted 09 July 2012 - 02:11 PM
Get off an old leak and at least get caught up with stock.
Posted 09 July 2012 - 02:15 PM
I ran the .79 leak for a long time and I definitely noticed battery issues.
Posted 09 July 2012 - 02:55 PM
lol, I haven't been keeping up obviously. Is 214 the OTA?
Posted 09 July 2012 - 03:07 PM
No, 214 is a valid leak, but only updates the kernel and some minor system bugs. Not official. Use utility version 1.7 after your firmly on 211.
Posted 09 July 2012 - 03:31 PM
you don't need to use the Utility 1.7 for anything to get to 214 if you are on stock OTA 211 tho unless you mean using it to fastboot back to 181 so the member can take the 211 OTA. FYI the 214 leaks flashes just fine over the top of 211. Heck I was on the 79 leak til last wk. I fastboot to 181 using RSD Lite, took the 211 OTA, then manually flashed 214 to finally root the device once all updates were done
