Smart Actions Won't Work
Posted 11 July 2012 - 08:03 PM
Thank you
Posted 11 July 2012 - 08:06 PM
I am currently running Full Throttle AOKP and have tried installing smart actions both as a system app and a normal app but neither will work for me. I'm just trying to get it to have like sleep mode and stuff at night, but none of the triggers seem to work. Anybody have any advice? Or a free/cheap replacement?
Thank you
Not gonna work. Smart actions need blur framework. That is an AOKP rom. No blur...
#3 Guest_BDH_*
Posted 11 July 2012 - 08:25 PM
Thank you
Like the post above me says, Smart Actions won't work on an AOKP ROM. You can try "Tasker" in the Play Store, it works just the same.
Posted 11 July 2012 - 08:52 PM
Sent from my XT912 using Tapatalk.
