Low Battery & Stuck In Boot Loop
12 replies to this topic
#1 markaddleman
markaddleman
  • Twitter:markaddleman
  • Google+:markaddleman
Posted 31 December 2011 - 04:29 PM
I ended up with a low battery while trying to install razrx. Now, I can't flash back to stock because of Low Battery, Cannot Program message in the Fastboot screen. I've tried turning off the phone (power+volume down) but the phone powers up and displays the Motorola boot image within a few seconds. It seems like the phone doesn't charge in this state.
Any suggestions?
#2 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 31 December 2011 - 05:31 PM
Leave it plugged into USB and off. I think someone mentioned that this worked for DroidTh3ory. Just leave it charging for a long time and it will eventually go up. That, or use a factory cable.
#3 markaddleman
markaddleman
Posted 01 January 2012 - 07:47 AM
Tried leaving the phone connected to USB all night but, still, the battery won't charge. Weirdly, the white LED comes on when I first connect to USB, remains on for about 30 minutes and then turns off. The phone still isn't charged (at least, not charged enough to flash).
Know of anybody that sells a factory cable?
#4 BBEvolution
BBEvolution
  • 132 posts
  • LocationNew York State
Posted 01 January 2012 - 09:50 AM
Team Black Hat @ My Droid World. Always out of stock, I think they should increase their stock and have higher minimum reorder points especially with the non removable Battery in the RAZR !!!!! WHAT DO YOU THINK TBH ?????
#5 rnlcomp
rnlcomp
  • 29 posts
  • LocationS.E. Louisiana
Posted 01 January 2012 - 11:33 AM
If you are adept with a dvom and have a usb cable you don't mind canibalizing you can always pop the back cover off, remove the rubber protective cover over the screws that hold the battery terminals on and get a couple spring loaded mini clips from radio shack and and charge it that way. Once you get the batt back up enough flashing should go as normal. I put in a request for a factory cable from BH but havent heard anything back from them yet.
#6 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 01 January 2012 - 09:36 PM
They just sold out of 25 of them. They are getting more in soon I will keep you guys updated.
#7 jtelander
jtelander
  • 134 posts
Posted 02 January 2012 - 11:42 AM
If you need a cable and/or want to know more about them...check out the series of tweets from Team Black Hat at
#8 wyld
wyld
    Some Kind Of Monster
  • 845 posts
  • Google+:rramos729@gmail.com
  • LocationPortage Indiana
Posted 02 January 2012 - 03:33 PM
Honestly I didn't know why those factory cables were so special until just recently. Now I want to get one! But I usually don't flash anything unless I'm above 50% battery life. I've never had a low battery issue if I need to sbf or fastboot or something.
Sent from my Rooted Droid Razr
#9 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 02 January 2012 - 03:36 PM
Im getting one because s*** happens. Also, I want to buy someones "broken" phone for cheap, fix it, then have an extra RAZR
#10 djsmurf
djsmurf
  • 9 posts
  • Twitter:djsmurf2000
Posted 02 January 2012 - 07:49 PM
I do also wonder if a portable power pack would work, might need to give it a try.
Donate $10 or more to our Phones For Devs Giveaway and get a Custom Forum title and help the Make a wish Foundation details here:
http://www.droidrzr....-custom-titles/
#11 (TSON)
(TSON)
  • 529 posts
Posted 02 January 2012 - 10:47 PM
Nope, those are just chargers
#12 ncwildcat
ncwildcat
  • 109 posts
Posted 14 February 2012 - 03:31 PM
Any suggestions?
I can't get mine to power off either...Need to charge this beitch up to fastboot
#13 jtelander
jtelander
  • 134 posts
Posted 14 February 2012 - 04:10 PM
