hi! i got this phone given to me and im trying to root it but i keep getting a binary code when i use razr blade/super us. what am i doing wrong? or is their a better/easier root app to run?
Posted 14 December 2013 - 05:32 PM
Posted 14 December 2013 - 06:08 PM
You have posted this in an intersting location. I am going to move it over to the 912 General forum
Posted 16 December 2013 - 02:18 PM
id like to root my phone could any one help me?
Posted 16 December 2013 - 05:52 PM
Posted 18 December 2013 - 07:01 AM
I would recommend doing a full factory reset on the phone as well as wipe cache, and dalvik cache( you can do this in the Stock Recovery menu of the phone, Power off the phone and before you power it back on, hold the Power button + both volume buttons and that will put you into the stock recovery of the phone. Press down on the Volume - button and select "Android Recovery" or whatever recovery. Youll know its the one cuz its gonna have a yellow triangle with a green android. Just hit both volume buttons again and it will give you a choice to factory reset , wipe cache, and dalvik cache. Once done just reboot the phone and try RAZR blade root again) if RAZR blade fails again then go ahead and download the MAXX Utility off this forum and use that rooting method through the utility.hi! i got this phone given to me and im trying to root it but i keep getting a binary code when i use razr blade/super us. what am i doing wrong? or is their a better/easier root app to run?
Posted 05 January 2014 - 01:55 PM
i did the matts utility and it worked. thanks for the help!!!!! does any one know of any apps/programs to overclock the phone?
Posted 05 January 2014 - 02:18 PM
i have safe strap 3.1
Posted 05 January 2014 - 02:34 PM
Posted 05 January 2014 - 03:31 PM
im running android 4.1.2
Posted 06 January 2014 - 05:55 PM
im having a problem with the aviator blur. i get a no md5 file
Posted 06 January 2014 - 06:04 PM
most of the custom roms dont bother with the md5
Posted 06 January 2014 - 06:08 PM
im using ss 3.65
Posted 06 January 2014 - 06:12 PM
I havent updated my 912 since my current device is a 926. In other versions of SS there is a check box for enabling/disabling the md5 check if that is what you are referring to
Posted 06 January 2014 - 06:13 PM
All of ZKK007's roms were my favorite on the 912 btw
Posted 06 January 2014 - 06:23 PM
So I turned on my 912. Under Advanced - Settings there is a check box titled "Zip file signature verifcation" it needs to be unchecked.
HTH
Posted 06 January 2014 - 06:24 PM
is it the skip md5 generation during backup or the enable md5 verification of backup files
