Options since bootloader is locked?
14 replies to this topic
#1 Huli
Huli
  • 20 posts
Posted 17 December 2013 - 05:12 PM
Since a few of us got onboard after the bootloader lockdown, what are our options to get our devices cleared up and running better? I have been disabling as much garbage as I can identify, a list off what can be disabled would be appreciated. I have noticed that restricting background apps does not do anything and that verizon remote assistance keeps running in the background. So yea, please advise.
Thanks!
#2 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 17 December 2013 - 05:19 PM
Are you rooted??
If so you can use Safestrap to load a few of the stock based roms
#3 Huli
Huli
  • 20 posts
Posted 17 December 2013 - 05:20 PM
No, i do not have that ability
#4 Memnoch73
  • 5,016 posts
Posted 17 December 2013 - 05:22 PM
Ouch! I'm sorry to say there is nothing to do at this time. No root=No fun. Lots of guys in your shoes. Sorry man...
#5 Huli
Huli
  • 20 posts
Posted 17 December 2013 - 05:30 PM
I am sure sombody out there knows what we can and cannot disable (not including the obvious like vzw crap)
#6 Memnoch73
  • 5,016 posts
Posted 17 December 2013 - 05:35 PM
If you're talking about disabling apps in the settings you're probably fine with doing anything you want. Especially Big V bloatware. There are de-bloated roms that have all that stuff removed and still function perfectly
#7 Huli
Huli
  • 20 posts
Posted 17 December 2013 - 05:39 PM
Yes, that is what I am talking about. Some items I can disable are not obvious. Attached is a screen shot of a few of the apps I am referring to. There are many more.
#8 Memnoch73
  • 5,016 posts
Posted 17 December 2013 - 05:44 PM
Yeah I wouldn't touch anything that is not a specific apk. All that com stuff is android related. Leave that going.
#9 Huli
Huli
  • 20 posts
Posted 17 December 2013 - 05:46 PM
That sucks. Just sitting idle my phone is at 87% RAM used. Soo bogged down that sometimes the keyboard locks up.
#10 Memnoch73
  • 5,016 posts
Posted 17 December 2013 - 05:50 PM
I hear ya man. Have you done a factory reset. Sometimes after updates things go screwy and a Factory reset helps out.
  • neckchop and cmh714 like this
#11 Huli
Huli
  • 20 posts
Posted 17 December 2013 - 05:52 PM
Really? I will try now. Brb
#12 johnthehillbilly
Posted 17 December 2013 - 06:07 PM
Also.... once you disable your choice of apps.... you should be able to boot into stock recovery and wipe cache.... that will help out a bit as well....:)
  • neckchop likes this
#13 Huli
Huli
  • 20 posts
Posted 17 December 2013 - 06:30 PM
Hmmm... I don't remember how to do that. Had the link saved on my phone... gone now. Lol. Would you be so kind as to remind me?
#14 johnthehillbilly
Posted 17 December 2013 - 06:34 PM
No problem....:) ...... you simply power off.... hold power and volume up + volume down .... when the menu come up... use volume down to highlight recovery .... then volume up to select it...... if the droid with the triangle comes up..... hit both volume buttons at the same time and you should boot into recovery...:)
#15 Huli
Huli
  • 20 posts
Posted 17 December 2013 - 06:54 PM
I guess the only ones with a good phone are the ones who have root. Full reset, disabled as many apps as I could figure, wiped cache. 76% RAM used at idle... le sigh.Posted Image
