[Stock-215] Ics.motoblur.6.16.215.deodexed.stock-R3Ds
#1 Guest_R3Ds_*
Posted 17 July 2012 - 01:03 PM
- cynnar, fergie44 and tbhall77 like this
Posted 17 July 2012 - 01:11 PM
#3 Guest_R3Ds_*
Posted 17 July 2012 - 01:26 PM
Posted 17 July 2012 - 02:50 PM
100% stock just deodexed,rooted,zipaling.
This is more or less a base for people to build off of for a custom ROM right?
Sent from my DROID RAZR using Xparent ICS Blue Tapatalk 2
Posted 17 July 2012 - 03:00 PM
Posted 17 July 2012 - 03:17 PM
Well it did say its for Safestrap in the OP...Any particular reason why I couldn't use bootstrap ICS for this?
Sent from my DROID SPYDER
Posted 17 July 2012 - 03:31 PM
Posted 17 July 2012 - 03:39 PM
Posted 17 July 2012 - 05:47 PM
Posted 17 July 2012 - 05:52 PM
Yes
Posted 17 July 2012 - 06:07 PM
Okay, poor choice of words. How about, could this be available for bootstrap?
Anything is possible if you aren't afraid to get your hands dirty. I'm still downloading this rom, but for Kebob's 211 deodex all you needed to do was modify his updater-script's mount commands. I'm expecting something similar on this one and needing to flash the 215 kernel separate.
Posted 18 July 2012 - 04:54 AM
X
#13 Guest_R3Ds_*
Posted 18 July 2012 - 06:31 AM
I don't think a deodexed rom can be flashed to non safe side because of moto signature.Any particular reason why I couldn't use bootstrap ICS for this?
R3Ds Themes
#14 Guest_R3Ds_*
Posted 18 July 2012 - 06:33 AM
The one in OP boots fine on safestrap.Have you gotten this to boot with safestrap? I just created a 215 stock, but cannot get 215 kernel to boot it. Anyone else having this problem?
X
R3Ds Themes
Posted 18 July 2012 - 06:35 AM
X
#16 Guest_R3Ds_*
Posted 18 July 2012 - 08:06 AM
i dumped the nonsafe system and deodexed that and made a zip for it. i used the 211 as the base but all the 215 system updates are included.Yeah I just flashed it. You dropped 215 right over hashcodes 211. I was trying to recreate it without using any of his files, just the edify code.
X
Posted 18 July 2012 - 08:19 AM
You left all that in your 215 you made from the 211 base. Just trying to figure out why these 4 or 5 files make the difference in booting or not.
X
Posted 18 July 2012 - 09:30 AM
Can someone identify these files though some are common sense.?. Sorry to kang your thread but you seem to be the first to release a 215 stock, so we might as well get it out of the way.
120.53KB 55 downloads
Thanks, X
Edit: I'll make this a new thread actually. Carry on.
Posted 18 July 2012 - 07:15 PM
Worked like a charm :-)
Much thanks.
Posted 19 July 2012 - 04:57 PM
It appears that .215 is baked into the ROM... no?
Sorry for being dense, but the OP said "to be used with the .215 kernel".
Thanks!
