Storage issue/question plz help
Posted 19 December 2013 - 03:37 AM
Alright I'm currently running cm11 4.4.1 installed via safe strap 3.65 considering my stock ROM is absorbing 2gb of my intenernal space I have very limited storage for apps. I was wondering if by purchasing a larger sd card and doing the internal/sd card swap will help me. Also which SD card is required
Sent from my XT912 using XDA Premium 4 mobile app
Posted 19 December 2013 - 09:12 AM
So if you have a 912, why did you post in the 910 forum?
You should have plenty of room I would think. As for an sdcard, you can swap some things out, but others dont behave well. I had good luck using a utility called DirBind. I have a SanDisk 64GB Class 10 SDcard.
Also let me know if you do have a 912 and I will move this over to the General section there please.
Posted 19 December 2013 - 09:47 AM
Posted 21 December 2013 - 04:40 AM
Posted 21 December 2013 - 07:08 AM
Ok, your problem is the internal storage is getting filled. The 912 has 16GB on board, but you can only access 8gb for your data. Once you install Safestrap, it then creates partitions for you slots of whatever size you create. I found the most useful setup was, I could run 1 or 2 slots in "live" mode (as in ready to bootup) and then any others I would just keep a backup handy for restoring.
What I found the easiest way is to start completely over. Not what most people want to do, but thats me. First make a backup of anything and everything if you dont want to worry. You would start by flashing with Matts utility or Sam's HoM to get back to a clean JB to start. After flashing, you should do a FDR with an internal data wipe, that can be done from the Settings menu. At that point you will be as clean and fresh as can be. Then install SS and enable it. Then make a backup of your Stock rom slot. Then create your slot and flash.
HTH
Also, moving to the 912 General forum
Posted 21 December 2013 - 08:44 AM
