lazy, I just found a hostapd.conf file that looks like the setup for the wap. I dont see a macaddr variable but one may exist that you can google for... assuming you have the file
It does have the SSID in there
Posted 12 January 2014 - 12:49 PM
Posted 12 January 2014 - 12:50 PM
May I ask how you're viewing the file? I just rename it as softap.txt and open it with Notepad, but I'm not sure if I'm missing any valuable information.
Posted 12 January 2014 - 12:51 PM
I just do it on the phone via root explorer. You can choose to view or edit if you want
Posted 12 January 2014 - 12:52 PM
Other file managers would have the same capability
Posted 12 January 2014 - 01:00 PM
When I open the files in ES Explorer the text is in both Chinese hanji and Arabic. Hoo, this is phone is giving me a hard time on purpose.
Again, I appreciate your help, cmh. I'll post again if I think I've got something.
Posted 12 January 2014 - 01:01 PM
interesting combination of languages. sounds like you should wipe and repave
Posted 12 January 2014 - 01:02 PM
and sure thing on the help seems like it should be relatively easy, but nah..
Posted 12 January 2014 - 01:14 PM
So in trying to figure this out with you what I just discovered is that the softap.conf file has the SSID and the password. Since its not a password I set, it could be random, or it could be a MAC.....gonna change it and play around more.
Posted 12 January 2014 - 02:45 PM
Keep me posted about your details!
I'll be copying the system files onto my desktop and checking nooks and crannies for such MAC configurations later on.
Posted 12 January 2014 - 03:49 PM
I suppose I found some clues to to where these configurations are located.
#! /system/bin/sh TARGET_FW_DIR=/data/misc/wifi/firmware TARGET_FW_FILE=$TARGET_FW_DIR/wl12xx-nvs.bin TARGET_NVS_FILE=/system/etc/wifi/wlan_fem.ini # Set MAC address from old PDS file to new file calibrator set upd_nvs $TARGET_NVS_FILE /pds/wifi/nvs_map.bin $TARGET_FW_FILE echo " ******************************" echo " * Finished Wi-Fi MAC calibration *" echo " ******************************"
Posted 12 January 2014 - 03:51 PM
mT ™ ùú ý !#) / 8 D J V d m ‰ Ÿ ¨ ± ýþþÿÿ ª ÿÿ ÷ïæÞ ? ÷ïæÞ ÷ïæÞ w€ "&')%"%%'# $%"PPPPPPPPPPPPPPPPPPPPPPPPPPPP -I don't know what's going on, but I'm thinking the MAC configurations are encrypted in one of those tricky .bin files.
Edited by lazy9090, 12 January 2014 - 04:08 PM.
Posted 12 January 2014 - 04:16 PM
Sweet! FINALLY! Just as I thought, they were in the .bin files!
Strangely, however, the MAC addresses were actually in both .bin files written.
I used a hexidecimal editor to view the two files, and they were the same (except for the end of the files, which don't really matter)
My MAC Address is 3C:XX:8E:XX:XX:83. But according to the hex editor, it starts from right to left, with some extra values added between them.
Now, I don't exactly know what to do with this information, but at least I have peace of mind.
Posted 12 January 2014 - 04:44 PM
sounds like it stored little endian style.
you can try saving the original and tweaking a new one to see if that works for you
Posted 12 January 2014 - 05:43 PM
Is that the term used? Sounds like something from Gulliver's Travels!
I would try to edit it, but there are values right in the middle of the MAC Address, shown here:
MAC Address: 3C XX 8E XX XX 83
Since I know nothing hexadecimal or binary related, I'll just pass this information on to the app developer that spoofs MAC addresses.
Really, thank you for the help cmh. There's really nothing much to do now, so I'm happy with what I got.
Posted 12 January 2014 - 07:00 PM
Alright! I just replaced the MAC Address value by value for both files. MAC is temporarily changed, but I got it.
Ahh, been going at it for days. You don't know the relief of MAC Addresses. Now I can stop procrastinating on homework!
Posted 13 January 2014 - 02:40 PM
Just wanted to post a small update; this isn't temporary, the MAC address is permanently changed.
However, if you have more than one ROMs in your system, it only changes the MAC Address on the ROM that is currently booted up, meaning you can have multiple MACs on the Droid.
Posted 13 January 2014 - 08:06 PM
Save the files with different names and macs in each and then use a program like Tasker to enable them and reboot. That way you can stay on the same ROM, if you want
