Used HD Maxx, BL unlocked. How to "start from scratch"?
Posted 12 January 2014 - 01:28 PM
Posted 12 January 2014 - 01:48 PM
- pistacio likes this
Posted 12 January 2014 - 01:50 PM
Posted 12 January 2014 - 02:06 PM
So flashing a new ROM (non SS built ROM) also flashes kernel with it, correct (since I'm BL unlocked)?
I'm still stuck in the safestrap state of mind, thinking that I need the latest stock kernel in place.
Sent from my DROID RAZR w/MAXX conversion using Tapatalk 2
- neckchop likes this
Posted 12 January 2014 - 02:44 PM
With an unlocked bootloader we are able to replace the Moto recovery with TWRP or CWM, most here use TWRP. Safestrap is not really a Recovery. But yes, rom and kernel are flashed all together. Lots of ROMS for unlocked bootloaders in the thread.
- neckchop and RikRong like this
Posted 12 January 2014 - 10:59 PM
If you do decide to FXZ back to stock, I would do it with House of Moto. Lately, it seems that RSD has caused nothing but issues. Also, like Chop said, I would just find a stock ROM and flash it in recovery. Personally, I prefer Mhous' DST builds:
. When I want a clean start, I wipe everything, including formatting data. FDR first, mount system, wipe date/system/cache/dalvik, then format data. This will effectively eliminate every bit of remaining data from the previous user (well, it should anyway).- neckchop and pistacio like this
Posted 16 January 2014 - 08:49 AM
Posted 16 January 2014 - 02:49 PM
Wiping all in TWRP is good enough for me.
I think I'm on an older baseband, running eclipse (my go-to ROM on my previous devices). Haven't noticed any real issues:
60.46KB 20 downloads
