I'm looking for icons that are text. Like the phone icon actually says phone
Icons
capt8210
, Jul 25 2012 08:08 PM
6 replies to this topic
Posted 25 July 2012 - 08:08 PM
Posted 25 July 2012 - 08:11 PM
You will have to use Apex or Nova to get it to work. Download "Simple Text" from the Play Store and you have 4 options to choose from.
Then change them by long pressing whatever you want to change. It will give option to change icon. I did it once but I plan on doing it again soon.
HTC One M8 // 3.28.605.4 // CleanROM 3.0 w/HarmonKardon audio // Android 4.4.4
- "White Noise" out November 4th! (Recommended)
Posted 25 July 2012 - 09:50 PM
That's too much work anyone with a flash theme
Posted 25 July 2012 - 10:55 PM
Yea I have text icons and can make them flashable for you. I'll post it in a few. Gotta work on it. I can get it done for you without changing launchers. Which icons do u want changed? I already have a flashable theme that will change phone/contacts, SMS, camera, web browser and unlock icon. I have more text icons tho if you want. I'll put up screenshots soon as well.
Posted 25 July 2012 - 11:12 PM
I should probably mention that I do not have a full icon pack set (only about 7 icons) and I did not create the icons, only used theme to make my own lockscreen theme. Which ROM are you running? I can show you some screenshots of some of the different layouts I have. Would you want white icons or ICS blue? Just let me know what you want, I should be able to get it to you really quick since that's what I've been working on recently.
Posted 26 July 2012 - 03:46 AM
White and I'm using ikream 215
#7 Guest_24v_*
Posted 26 July 2012 - 03:58 AM
The problem with flashing a theme rather than using skinned icons in a launcher is that when you update any of the themed apks you will lose the icon until someone changes the theme again for you. Better to go the launcher route imho.
- andlaw likes this
