I need help…PLEASE! I rooted my DROID Razr 2 days ago using Razr Blade. I'm sure I did everything right since it's so simple to do (just follow the prompts). I didn't have any issues with that. Yesterday, I decided that I wanted to start fresh with my rooted Razr so I downloaded Titanium Backup, backed up everything to my SD card and performed a factory reset. This is what I'm working with, what I did, and what happens...
Droid Razr XT912
System Version: 98.72.16.XT912.Verizon.en.US
Android Version: 4.1.2
After performing the factory reset, I started setting up the phone. I got all the way to the screen where you setup your Google acct and that's when I got the window saying, "Unfortunately, setup has stopped." I press OK and the screen goes blank. I tried again (factory reset) and got the same exact results. I cannot get it to finish setup for some reason. I've tried multiple times.
I also tried wiping the cache and rebooting. When I did that, it got past the boot up animation screen and I got a window saying, "Android Upgrading" and either, "starting apps" or "finishing boot." I waited for a while to see if it would, in fact, finish but it never did. The last time I tried, I let it "upgrade" ALL NIGHT and woke up this morning to the same screen, "Android Upgrading". The only way I can get it to stop is to have someone call me which I guess interrupts the "upgrading" process.
I can make and receive phone calls but that's it so I don't think it's bricked. I don't have a home screen (it's blank), no apps, nothing! Does anybody have ANY idea what I can do. I'm stuck!
This is where I got Razr Blade from:
