so I keep getting the error in fastboot anyhelp?
Device Is Locked, Status Code: 0
Battery OK
no valid PIV block in SP for system
piv validation failed (system)
Fastboot Reason: Boot Failure
Posted 16 January 2014 - 12:40 AM
Battery OK
Posted 16 January 2014 - 01:37 AM
What where you attempting to flash?
Posted 16 January 2014 - 03:39 AM
No I accidentally Erased Everything. With Out knowing while I was using safe strap I cleared Everything on primary Partition
Posted 16 January 2014 - 04:14 AM
Posted 16 January 2014 - 06:41 PM
what FXZ the generator or the FXZ flasher?
Posted 16 January 2014 - 06:51 PM
Posted 16 January 2014 - 07:07 PM
That would be one limitationIt works but with severe limitations. And I'm on vacation.
Sig by
Posted 17 January 2014 - 06:43 AM
Alright. Im Going To Take My phone To Verizon Will They Give Me A Replacement Since I Still Have A Warranty? Nothing Seems To Be Working
Posted 17 January 2014 - 06:48 AM
Huh?? Did you use the FXZ? That should work fine.
Posted 17 January 2014 - 06:49 AM
Yes But it finishes But does not reboot the phone. the phone just stays in fastboot.
Posted 17 January 2014 - 07:02 AM
What happens when you reboot??
Posted 17 January 2014 - 07:06 AM
it goes back to fast boot i cant load up the system.
Posted 17 January 2014 - 07:10 AM
Does it give you any error or failure on the fastboot screen?? Did you try to run the FXZ again??
Posted 17 January 2014 - 07:14 AM
maybe a FDR???
Posted 18 January 2014 - 07:34 AM
Can You Walk Me Through How To Use FXZ?
Posted 18 January 2014 - 09:01 AM
Sig by
Posted 18 January 2014 - 01:23 PM
Alright thanks It Worked
