SuperSU and Superuser
4 replies to this topic
#1 rangerm
rangerm
  • 25 posts
Posted 17 January 2014 - 03:37 AM
I lost root after the recent OTA and re-rooted my XT912 yesterday using Matt's utility (1.82, I think is the latest).
I'd installed SuperSU after I'd rooted before, and now after re-rooting I also have Superuser which I'm assuming was installed as part of the utility.
Is there any reason I need both?  If not, which should I uninstall?
#2 cmh714
Posted 17 January 2014 - 06:00 AM
You could remove either basically since they do the same thing. And yes, Matts utility install Koush's Superuser with the blue icon and hash sign.
  • mjohnson likes this
#3 LDubs
LDubs
    Pawn In Game of Life
  • 9,137 posts
  • Twitter:lew_bklyn
  • LocationBrooklyn, NY
Posted 17 January 2014 - 06:01 AM
You don't need both.  Only one will work anyway.  Matter of personal preference...
edit: ninja'd by CMH!
  • cmh714 and mjohnson like this
#4 larrygeary
larrygeary
  • 160 posts
  • LocationNJ, USA
Posted 30 January 2014 - 11:12 AM
If you want to keep SuperSU, there is an option inside the program to uninstall other superuser programs. I wasn't able to uninstall Superuser through the Playstore link.
#5 rangerm
rangerm
  • 25 posts
Posted 06 February 2014 - 04:28 AM
I wound up uninstalling SuperSU, since the utility installed Superuser by default, and installed Voodoo for future OTAs (if they ever come).
