Razr With Strange Issues
Posted 27 July 2012 - 09:37 PM
Posted 27 July 2012 - 10:10 PM
Posted 27 July 2012 - 10:34 PM
Posted 27 July 2012 - 10:43 PM
Posted 27 July 2012 - 10:44 PM
Posted 27 July 2012 - 10:51 PM
Posted 27 July 2012 - 10:58 PM
Posted 27 July 2012 - 11:03 PM
Posted 27 July 2012 - 11:06 PM
Posted 27 July 2012 - 11:07 PM
Posted 27 July 2012 - 11:09 PM
Posted 27 July 2012 - 11:11 PM
Posted 27 July 2012 - 11:14 PM
Posted 27 July 2012 - 11:16 PM
Posted 28 July 2012 - 03:06 PM
Posted 28 July 2012 - 03:19 PM
still cant get anything to allow me to get into recovery if anyone has any sugestions or walk throughs i would be very greatful....
you can't get to fastboot either?
Posted 29 July 2012 - 05:56 AM
Working volume keys are needed to fastboot which at this point is a major prob. If RSD lite isn't working either then I have no idea. At this point I'd try anything, even pulling the SD card to see what happens.
Posted 29 July 2012 - 06:48 AM
Open a command prompt from the folder where advanced is installed (you can use the one from Matt's utility). Boot your phone (safe mode should work as long as USB debugging is checked) and connect your it via usb and type "adb reboot recovery". The phone should reboot into recovery. To get into AP fastboot mode, follow the same directions but type "adb reboot bootloader" instead.
Quickboot and Moto Reboot from the Play store will perform these functions too. Without the need for the USB connection.
Posted 30 July 2012 - 03:22 PM
