Wiping Phone Completely
Posted 30 July 2012 - 08:53 AM
Posted 30 July 2012 - 09:07 AM
I was just wondering if there's an easy way to completely wipe all traces of me from my phone. I'm gonna be selling it in the next couple days to move to Canada and want it to as close to bone stock as possible. I've done factory resets, but folders and backups stay on the internal SD and I want to wipe all of that completely. Any ideas?
I would pretty much do this...
Install Bootstrap
Remove your SIM card (so it can't re-attach to an account)
Scrub the partitions you want to in Bootstrap (will soft brick you if you get as aggressive as I would)
Fastboot
Posted 30 July 2012 - 10:16 AM
Posted 30 July 2012 - 10:44 AM
Yes what he said. I personally use, Disk Usage app. It will show every thing you have on both sd. And ext. Delete from there. But be careful what you delete. I use it to ensure no residuals are lingering when reverting.I'm pretty sure just removing your external sdcard, erasing the internal storage from settings > storage, rebooting to stock recovery and doing a FDR will pretty much wipe any trace of your personal info, but snives method will be more thorough and pretty much guarantee none of your personal data could be recovered.
Posted 30 July 2012 - 07:20 PM
Posted 31 July 2012 - 09:57 AM
anytime!Good ideas, Thank you for your help!
