Auto Rotate Stuck.....ughhhhh!
Posted 30 July 2012 - 11:31 AM
Rooted, Over clocked droid maxx running ICS with Full throttle AOKP ,
Today I plugged my Headphones in to my phone (which I usually never do) and it rotated into landscape and after 2 reboots it has still not come back to portrait(stock), Firstly I am not running any apps that require a landscape I am using ADW launcher, which rotates automatically, I do not Know how or what I did to have this situation But I would love to find a way out of it!!!!!any suggestions?
Posted 30 July 2012 - 11:52 AM
Posted 30 July 2012 - 11:56 AM
Posted 30 July 2012 - 12:45 PM
I have the same issue and it is activated in settings, I do not have ADW. Mine is keep telling me that I have HDMI connected and asking to activate one of the HDMI modes (WebTop, Duplicate screen etc...). I am not sure what to do, also I cannot activate AP FastBoot mode too.And check it in both system settings and in the ADW Launcher settings.
Can you help?
Posted 30 July 2012 - 12:58 PM
Posted 30 July 2012 - 01:02 PM
Can you help?
I have the same problem. It is a hardware issue with your phone. If you want it to stay on portrait you have to go into settings>display and check enable hdmi detection and then uncheck it. (even if it is unchecked already just recheck and uncheck it.) did some research online and its a common issue. I had a Verizon rep confirm this as well. I placed a replacement order that should be here tomorrow. I suggest replacing your device before your original warranty becomes void and your stuck with it.
