fastboot low battery
fastboot battery
2 replies to this topic
#1 nlaskoski2009
nlaskoski2009
  • 7 posts
Posted 23 January 2014 - 03:32 PM
i have a soft brick on my razr m and i have yet to buy a the micro usb that is needed, but i was wondering if the green light is on while plugged into the wall means its charging? it stays green for about 1 minute before turning onto flash boot. i also found that if i hold the power button down it holds at the M splash screen before going to the fast boot screen. does this mean i can tape down the power button and let it charge?
#2 shawnsingh100
shawnsingh100
  • 12 posts
Posted 19 February 2014 - 06:08 PM
#3 shawnsingh100
shawnsingh100
  • 12 posts
Posted 19 February 2014 - 06:09 PM
If you turn off your phone you should be able to charge
