Rooting Driod Razor Maxx On 215
Posted 02 August 2012 - 03:11 PM
Posted 02 August 2012 - 03:16 PM
Posted 02 August 2012 - 03:39 PM
Posted 02 August 2012 - 03:53 PM
Posted 03 August 2012 - 05:53 AM
Posted 03 August 2012 - 09:11 AM
Posted 04 August 2012 - 06:05 AM
Posted 04 August 2012 - 07:01 AM
Posted 04 August 2012 - 07:59 AM
+1Use Matt's utility to flash back to 211 then update to 215 again.
Posted 04 August 2012 - 04:47 PM
#11 Guest_24v_*
Posted 06 August 2012 - 03:26 AM
Posted 06 August 2012 - 04:08 PM
If your battery is low you will not be able to fastboot. You will need a factory cable to charge it first. If you search for moto factory cable you will find places to buy them as well as links that show you how to make one from a regular usb cable.
This is only half right. A factory cable doesn't charge your phone. It powers the phone while it's flashing allowing you to flash the phone with a low/dead hell, no battery at all. Just FYI :-)
#13 Guest_24v_*
Posted 06 August 2012 - 04:14 PM
