Pulldown Toggle Mod For Standard 215 Deodexed Rom?
Posted 05 August 2012 - 12:50 PM
Are there any such mods for a standard Deodexed 215?
Thx!
Posted 05 August 2012 - 01:06 PM
- sankyou likes this
Posted 05 August 2012 - 01:18 PM
Posted 05 August 2012 - 04:33 PM
34.34KB 66 downloads
You can change the icons to anything you like... rotate the image with an image editor if you want them sideways.... I made mine red instead of blue...
Posted 05 August 2012 - 09:46 PM
Thanks. Installed this and converted it to a system app so it has direct toggles of GPS, and background data. Works like a champ and has more toggles than AOKP/CM. I'd imagine this takes slightly more resources than having it integrated with the ROM but it will do until we have some more options.There is an app in the play store called notification toggle that works just as good... its free and you can customize the toggles and icons even set up a toggle to launch any app you want... its easy to set up and works really good with ICS
Posted 06 August 2012 - 01:56 AM
Can you go through the rotation step? I've tried other icon packs, and they won't properly load.This is how I have mine set up:
Posted 06 August 2012 - 04:07 AM
Which style of icons do you want rotated?
Sent from the cutting edge of my Droid RAZR MAXX
Posted 06 August 2012 - 07:24 AM
Posted 06 August 2012 - 07:36 AM
Right now I'd take any. I'm using the NT icon downloader app, but every time I choose something other than default I get a big white square instead of the icon....
That's strange... did you select a color in the app? Maybe revert colors to default... I had a weird looking icon when I tried the in app colors... I ended up modifying them with "photo editor" (free in the play store) because the app didn't color them correctly...
Posted 06 August 2012 - 08:15 AM
Sent from my Droid Razr Maxx Arctic .215
Posted 06 August 2012 - 09:01 AM
Posted 06 August 2012 - 09:25 AM
That was it--I had tinting on the custom icons. Where are the icons stored, BTW?That's strange... did you select a color in the app? Maybe revert colors to default... I had a weird looking icon when I tried the in app colors... I ended up modifying them with "photo editor" (free in the play store) because the app didn't color them correctly...
Posted 06 August 2012 - 03:26 PM
With my prior knowledge of the Notification app, I've noticed that on of the shortcomings of the app is that it doesn't sit at the top of the notification bar when other notifications are present. Sometimes it jumps around depending on other notifications.... not a big deal, but it was a little annoying...Did they fix this? Can anyone confirm that this still happens?
Not an issue with ICS... if you turn on the accessibility service for it, it always stays on top
Posted 06 August 2012 - 03:27 PM
They are in a folder on your internal SD.... you should be able to find them through the stock gallery.
Posted 06 August 2012 - 05:13 PM
Pretty nice though. Set NT as system app and you get the full features. I use it for toggles and direct calls.
-- Living Life From My RAZR's Edge --
Posted 07 August 2012 - 02:06 AM
It still is a little loopy at times. It wouldn't stay at the top even with accessibility service when My music was playing, but overall they seemed to have fixed that problem. After a reboot or two as a system app, the jumping around seems to settle down.Not an issue with ICS... if you turn on the accessibility service for it, it always stays on top
Posted 12 August 2012 - 10:06 AM
Posted 13 August 2012 - 12:22 AM
Looks more like ICS and the native flash light toggle and lock toggle work without installing additional apps or short cuts.
The toggles also are "in sync" with the status bar. "Active" "non-active" states match status bar.
(Both were short comings in Notification Toggle.)
App also can display battery % in status bar.
Posted 13 August 2012 - 01:16 PM
I recommend power toggles.
I like this app for the way it looks and the native flashlight, but it is behind curve for being able to directly toggle GPS. Even making it a system app still brings up location settings instead of just toggling GPS on/off. Both NT and Widgetsoid will toggle GPS directly if set as a system app. Both will also display battery percent in the status bar.
If you want direct GPS toggle, there are only a few choices. Notification Toggles and Widgetsoid are still the most complete I've tried.
Posted 13 August 2012 - 08:55 PM
