Gps Tweaks
Posted 05 August 2012 - 06:15 PM
Posted 05 August 2012 - 06:19 PM
Worked great for me
Posted 05 August 2012 - 06:23 PM
I set it up and am getting fast locks, however I have always gotten a fast lock so that is nothing new. It also saves your original gps.conf to easily restore it later should it give you issues.
Posted 05 August 2012 - 07:16 PM
Thanks man, first I've heard of this app.Faster GPS for free on the market does the same tweaks, much more conveniently.
Posted 06 August 2012 - 01:58 AM
Can you post the apk? Says it's not compatible with my device
Posted 06 August 2012 - 02:19 AM
Same for me.
Sent from my .215 Arctic RAZR
Posted 06 August 2012 - 03:00 AM
Same for me.
Build from source yourself:
Direct download by author:
Posted 06 August 2012 - 04:26 AM
Posted 06 August 2012 - 03:03 PM
Thanks. I was able to install on my tablet but the app is different than this one. I'll give this a go.
Here's the one i have on my tab. I copied out over to my razr and works good as well.
- MasterGadgets likes this
Posted 06 August 2012 - 03:23 PM
Posted 06 August 2012 - 07:49 PM
I'm on .215 kernel and simplexrom and after using the navi all day today I noticed there really is no need for GPS tweaks. It locks on within 3 seconds TOPS. Good replies but for now I don't see the need for GPS tweaks the way my phone is running.
I'm on the new simple rom too. It must be hit or miss cause I'm a 215 and GPS takes forever to lock. I usually have to toggle it on and off if it hasn't locked after first turning it on. Had this problem on every rom even stock
Posted 07 August 2012 - 01:00 PM
Did you make sure you are outdoors and not in a building
